Low beam bulb failure, possible reasons? (2006 V70) Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
hughiescho wrote: 19 May 2023, 18:41 So after noting low beam bulb is indeed not lighting, I pulled out the air box to access the bulb from rear of headlight assembly. It appears one of the two female receptacles that the bulb plugs into is broken. See image. I am going to try source a new "plug" locally tomorrow. Hopefully it is just from age.
I see one pin is burnt.
hughiescho
Year and Model: 2006 V70 2.5T
Has thanked: 15 times
Been thanked: 3 times
Post by hughiescho »
Yes, one pin is burnt and broken.
hughiescho
Closing the story on this issue now. I bought a generic receptacle with pig tails from the local parts store, then took off front bumper cover to remove headlight assembly so wiring could be done indoors with sufficient space. After reassembly bulb lights, so I will button up the bumper cover tomorrow after a little cleaning.
When cutting and stripping original wires on headlight assembly I noted the copper wires were dark with corrosion even under the insulation. I am hoping this is normal and expected considering they are now 17 years old.
Has thanked: 311 times
Been thanked: 817 times
Thanks for following up with the resolution! Good luck sounds like you have it beat.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
hughiescho wrote: 20 May 2023, 21:22 Closing the story on this issue now. I bought a generic receptacle with pig tails from the local parts store, then took off front bumper cover to remove headlight assembly so wiring could be done indoors with sufficient space. After reassembly bulb lights, so I will button up the bumper cover tomorrow after a little cleaning.
dialectric grease helps stop this , moisture gets past the rubber seal on the plug, green gremlins start growing, increasing resistance becomes heat and plastic parts melt.
hughiescho
jonesg wrote: 24 May 2023, 16:00
Good tip--thanks Jonesg!
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
I seem to recall having some issues with the receptacle as well. Can't quite remember that I replaced it with (amazon, ebay) or maybe I just snipped one off from the junkyard. Also recall something about getting ceramic receptacles. Sorry, my memory is failing me at the moment.
