Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
as far as i know its not possible. you have to have a dump of the cem to gain the pin or crack it.sunjacobc wrote: 26 May 2023, 02:00 Who can directly obtain the vehicle PIN through the VIN and contact me
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Perhaps, yes? If it uses the same principle like CEM pin code.volvofrank wrote: 21 May 2023, 02:42 @vtl: Do you know if it's possible to retrieve / brute force / time attack the Immobilizer Code as well?
Or do you know the steps needed....?
I am on a Volvo P1.
nikemen
- Year and Model: 2012 C30 T5
- Has thanked: 3 times
Hello there !
I'm sorry if what I asked was answered before, I searched it but didn't find it.
I got the PCB from https://www.pcbway.com/project/sharepro ... 037d5.html and soldered the Teensy and the CF160 chips.
All I get is this, no matter in what position the car's key is in:
I'm thinking the problem is the lack of R1 and R2 in the PCB design. I wrote to the designer but got no answer.
I'm a total newbie, can someone help me get this running ?
PS: My car is a 2012 C30 T5.
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
PIN bytes to measure: 3
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
Unknown CEM part number 0. Don't know what to do.
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00I'm a total newbie, can someone help me get this running ?
vtl
Try to comment out CEM_PN_AUTODETECT: https://github.com/vtl/volvo-cem-cracke ... er.ino#L14nikemen wrote: 08 Jun 2023, 14:11 I'm thinking the problem is the lack of R1 and R2 in the PCB design. I wrote to the designer but got no answer.
Also if I remember correctly, P1 cracks without key inserted. You may want to try that first.
oscilloscope
Folks I know this thread is regarding the cem cracker.
Now in the background I have been looking to reverse engineer the old synchro software which was avaliable from Codecard for the sid807evo with the white cem 2. It has not been easy I had to inlist some help from a developer who more about the encrypted data which was shielding certain parts of the program. , anyway further digging it was discovered that the program is no more then a glorified gateway and none of the synchronisation is performed locally it's performed on a remote server or even a human does it who knows , since the software has been discontinued there is no chance of finding this out
Now My next question is , if I where to go it alone and Try to make my own software which performs this task. My guess is I can capture the packets from DiCE via vidia. , and "see" what or how it is performed on a test mule vehicle. And then analyse the bin file before and after.
Firstly what tools should I use ?
I'm guessing a CAN bus capture oscilloscope, or a logic analyzer, directly connected too the ram on the cem & ecu or the mcu of both modules.
Thoughts , suggestions , ideas , whatever cool beans
- prometey1982
- Year and Model: 2010 XC90
- Been thanked: 5 times
You need to use CAN sniffing software like CAN hacker. It's very strange to use oscilloscope to analyze CAN packets.oscilloscope wrote: 10 Jun 2023, 10:20 Folks I know this thread is regarding the cem cracker.
Now in the background I have been looking to reverse engineer the old synchro software which was avaliable from Codecard for the sid807evo with the white cem 2. It has not been easy I had to inlist some help from a developer who more about the encrypted data which was shielding certain parts of the program. , anyway further digging it was discovered that the program is no more then a glorified gateway and none of the synchronisation is performed locally it's performed on a remote server or even a human does it who knows , since the software has been discontinued there is no chance of finding this out![]()
Thoughts , suggestions , ideas , whatever cool beans![]()
Они просто сдохнут, а мы попадем в рай.
vtl
Get a cheap logic analyzer, capture the CAN traffic. Most likely your software uses standard protocol. Then you'll see what it writes to which addresses.oscilloscope wrote: 10 Jun 2023, 10:20 Folks I know this thread is regarding the cem cracker.
vtl
Modern digital oscilloscopes have packet analyzers. My not the most expensive Rigol DS2072A does it, and I bought it a decade ago. It is not the most convenient, especially without control software on a PC. I prefer a dedicated logic analyzer.prometey1982 wrote: 10 Jun 2023, 16:25 You need to use CAN sniffing software like CAN hacker. It's very strange to use oscilloscope to analyze CAN packets.
oscilloscope
I do have a oscilloscope but not the logic analyzer add-on , i think it's probably time to buy the add on...vtl wrote: 10 Jun 2023, 17:56Modern digital oscilloscopes have packet analyzers. My not the most expensive Rigol DS2072A does it, and I bought it a decade ago. It is not the most convenient, especially without control software on a PC. I prefer a dedicated logic analyzer.prometey1982 wrote: 10 Jun 2023, 16:25 You need to use CAN sniffing software like CAN hacker. It's very strange to use oscilloscope to analyze CAN packets.
- 9858 Views
Last post by RickHaleParker
- 10187 Views
- 27 Replies
- 31330 Views
Last post by cn90
- 10 Replies
- 11974 Views
Last post by jonesg
- 6946 Views
