I think it was circular when Bjorn, with a small lip on it. That square thing on left was probably solid with a gap for something.
Im lost after that.
Name that rusty part
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I had to mangle it to remove it, obscuring it's original shape. It's about as big as a quarter and was circular. No rust because I believe it's aluminum. It's easy to guess what it is, but exactly where was it installed?
FireFox31
I’m still stumped. Sunroof, wheel bearing, brakes??
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
The clues of "round, aluminum" make me think it could it have been an aluminum drain plug gasket installed on the engine oil or the transmission fluid sumps. Getting any warmer?
- Has thanked: 2200 times
I think you got it! If you squint and imagine hard you may see it................?!
Clip holding on transmission oil lines?
I like the drain gasket answer but having trouble seeing how that could get mangled like that.
Here’s my entry for Sunday
- jreed
A rear bumper bracket and bracket bolt?
Neil
Neil
- FireFox31
You're right, it's the engine oil drain plug gasket. 50 more MVS points to jreed. You're quite good at this.jreed wrote: 27 May 2023, 06:37 The clues of "round, aluminum" make me think it could it have been an aluminum drain plug gasket installed on the engine oil or the transmission fluid sumps.
The drain plug was installed to such a high torque that the gasket was almost conical. It's likely that no previous technician changed the gasket so it leaked, thus they overly tightened it to stop the leak. You can still see the conical impression in the upper part of the "after removal" picture, but hopefully see it clearly in the "before removal" picture below.
The gasket diameter was also deformed so much that it would not fit over the plug threads. To remove it, I had to fight to get a tiny grip, then stretch it to get a better grip, repeat until I could fatigue the metal enough to break it.
FireFox31
- 4401 Views
Last post by 93Regina
- 1754 Views
Last post by oragex
- 711 Views
Last post by voom8
- 2351 Views
Last post by seanj
- 23 Replies
- 6323 Views
Last post by Phantomphixer
