1997 Volvo 850 GLT Turbo - very small hose above lower radiator hose in engine bay is broken.
moses3
Year and Model: 1997 850 GLT
Has thanked: 68 times
Been thanked: 5 times
Post by moses3 »
What is this hose for? Does anyone know a part number?
Been thanked: 4065 times
It’s a vacuum hose for the heated air motor on the air cleaner
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 28 May 2023, 18:19 It’s a vacuum hose for the heated air motor on the air cleaner
I thought turbos didn't get that? I switched to a turbo lower box, to get rid of mine. Mine is a 96, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2200 times
Been thanked: 1852 times
Turbos don't have them. There is a small hose that runs to the PTC nipple area on some turbos and to the top of the snorkel on the older engines if I recall correctly.
moses3
Post by moses3 »
Mine has it, and it has a turbo. Maybe the turbo was added later, because I don't have a turbo gauge on the dash or an air filter box marked turbo.
Other vacuum operated stuff nearby…
Hot air motor noted above
supplemental air system solenoid, mounted high behind radiator
Cruise control?
EGR system, unlikely in a 1997
454cid
Post by 454cid »
moses3 wrote: 28 May 2023, 23:47 Mine has it, and it has a turbo. Maybe the turbo was added later, because I don't have a turbo gauge on the dash or an air filter box marked turbo.
The GLT is a low pressure turbo.... no boost gauge or "Turbo" script on the airbox. My 99 S70 GLT doesn't have those things either.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I think my '97 855 GLT also had a hard white hose like this, with a crumbly rubber elbow, and it was part of the SAS system, connected to the solenoid valve on top of the radiator as abscate mentions above. If you're keeping it, I would recommend using a piece of silicone hose to replace the rubber elbow because the rubber elbows don't seem to have a long lifetime -- maybe 2-5 years at best and possibly less depending on which elbow location. The silicone hose is flexible enough to make a bend similar to what's molded into the elbow.
moses3
Post by moses3 »
jreed wrote: 29 May 2023, 07:33 I think my '97 855 GLT also had a hard white hose like this, with a crumbly rubber elbow, and it was part of the SAS system, connected to the solenoid valve on top of the radiator as abscate mentions above. If you're keeping it, I would recommend using a piece of silicone hose to replace the rubber elbow because the rubber elbows don't seem to have a long lifetime -- maybe 2-5 years at best and possibly less depending on which elbow location. The silicone hose is flexible enough to make a bend similar to what's molded into the elbow.
How can I use a silicone hose to replace the rubber connector? One side of the rubber connector is wide, where the other side is narrow?
jreed
Post by jreed »
I had that concern too -- flexible thick wall silicone tubing worked. You can get a tight seal on the narrow end and still be able to stretch the tube over the larger fitting on the other side.
