1997 Volvo 850 GLT Turbo - very small hose above lower radiator hose in engine bay is broken.
moses3
- Year and Model: 1997 850 GLT
- Has thanked: 68 times
- Been thanked: 5 times
What is this hose for? Does anyone know a part number?
- 20230528_163508.jpg (329.85 KiB) Viewed 698 times
- Has thanked: 1502 times
- Been thanked: 3817 times
It’s a vacuum hose for the heated air motor on the air cleaner
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
I thought turbos didn't get that? I switched to a turbo lower box, to get rid of mine. Mine is a 96, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1842 times
- Been thanked: 1710 times
Turbos don't have them. There is a small hose that runs to the PTC nipple area on some turbos and to the top of the snorkel on the older engines if I recall correctly.
Other vacuum operated stuff nearby…
Hot air motor noted above
supplemental air system solenoid, mounted high behind radiator
Cruise control?
EGR system, unlikely in a 1997
Cruise control?
454cid
The GLT is a low pressure turbo.... no boost gauge or "Turbo" script on the airbox. My 99 S70 GLT doesn't have those things either.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I think my '97 855 GLT also had a hard white hose like this, with a crumbly rubber elbow, and it was part of the SAS system, connected to the solenoid valve on top of the radiator as abscate mentions above. If you're keeping it, I would recommend using a piece of silicone hose to replace the rubber elbow because the rubber elbows don't seem to have a long lifetime -- maybe 2-5 years at best and possibly less depending on which elbow location. The silicone hose is flexible enough to make a bend similar to what's molded into the elbow.
moses3
How can I use a silicone hose to replace the rubber connector? One side of the rubber connector is wide, where the other side is narrow?jreed wrote: ↑29 May 2023, 07:33 I think my '97 855 GLT also had a hard white hose like this, with a crumbly rubber elbow, and it was part of the SAS system, connected to the solenoid valve on top of the radiator as abscate mentions above. If you're keeping it, I would recommend using a piece of silicone hose to replace the rubber elbow because the rubber elbows don't seem to have a long lifetime -- maybe 2-5 years at best and possibly less depending on which elbow location. The silicone hose is flexible enough to make a bend similar to what's molded into the elbow.
- jreed
I had that concern too -- flexible thick wall silicone tubing worked. You can get a tight seal on the narrow end and still be able to stretch the tube over the larger fitting on the other side.
