99-00 Volvo V70 Speaker wiring diagram - Dolby
- Has thanked: 2198 times
- Been thanked: 1851 times
I looked on the underside and the barbs look fairly permanent. Do they break off when you force it upwards? The whole thing looks like ti will rip off the top of the dash before it will come loose! I will put it aside for now and concentrate on getting the car running. I can return to this this winter when it goes into hibernation again.
Thanks,
Thanks,
That was exactly what I thought. There was no way those barbs were coming out without something breaking!
Many thanks for the info. That project can wait for now. Old dash pad will get returned for now and this will be a winter project.
Thanks,
Thanks,
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Not to flex but i've removed a few of them without breaking the tabs
It is a bit scary the first time, but it you dont push the cover sideways it's fine. Worse case, a bit of epoxy will make them stronger than ever !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I had to replace the original speaker several
years ago. It failed like all of them do and a
chunk of the magnet was rolling around in
the speaker cone. Swapped it with the new
version with no grill damage.
IIRC, I got under the frame of the grill with a
bone tool and just worked my way around.
Thanks for that. I'll try again at some point. Need to get the car running by the weekend so no more time to play with that project.
If the tabs break the cover can be held down with some Velcro. Two tabs on each side
We lost our old dog today. To distract myself I decided to have another look and if it broke it broke. The issue I found was that the outer cover actually sits lower than the plastic plate that holds it in place. You have to start at the front and as someone suggested a bone tool
(or 2 ideally I found) allowed me to get up under the edge and on top of the holding plate. Even though it was cracked the RF pin suddenly popped loose, I then managed to do the same on the FL. Then working around the edge with both tools the rear 2 also popped loose.
That was when I found the lemon I have been sold is worse that I thought. I will add pictures with the details later.
All of us pass our condolences on your furry family members’ passing..
- 4145 Views
- 1205 Views
- 1804 Views
Last post by raivis_rsn
- 506 Views
Last post by BlackBart
- 11 Replies
- 1086 Views
