If you can use a mirror and get the part number on it which is on the lower face of it, I believe Matty still does an exchange where he sends you a repaired unit so you can fit ti and then you return your unit as a core once the new one is up and running.
Replacing the unit will not fix the broken on missing bulbs on the dash though.
Speedometer Dead
- Has thanked: 1855 times
- Been thanked: 1717 times
Re: Speedometer Dead
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hello Neil,scot850 wrote: ↑28 May 2023, 06:15 If you can use a mirror and get the part number on it which is on the lower face of it, I believe Matty still does an exchange where he sends you a repaired unit so you can fit ti and then you return your unit as a core once the new one is up and running.
Oh that's too bad, i thought fixing the ABS thing was going to fix the burnt out bulb in the garage too (hee hee).
Ok same problem came up. I went to the store about 1 mile from here, speedometer worked fine. When i came out, on the way back, it's dead again. I guess i have to find something better than cardboard.
But it's strange that it would work on the way to the store then on the way back it doesn't work. Doesn't make sense.
So something better than cardboard to try i guess, for now.
One good thing still though, at least i know what the problem is, and that's 90 percent of the repair i think.
My buddy used a golf tee.....!
Neil
Neil
- MrAl
Oh what an idea ha ha.
I have popsicle sticks ha ha.
I think he ran the car like that for about 2 years. Not sure if Volvo have an official part number for it yet??
- MrAl
I checked with Volvo, they are not available anymore
- Has thanked: 1508 times
- Been thanked: 3827 times
Only of you are in the green, driving club.
That’s a triple!
- MrAl
Hi Neil,
I meant to ask you, how hard do you have to jam something in there to get it to work?
When i put the cardboard, it was hard to get into the very narrow space between the ABS unit and that black box thing on the side/front.
I don't want to press too hard, but i want it in there tight enough.
I have some skewer sticks i think will be great for this, they have one pointed end and are about 1/8 inch in diameter.
- MrAl
Hi Steve,
I am going to try some skewer sticks (ha ha). I got two yesterday with a chicken shish kabob. They look about the right diameter for this job.
