Nice. Thank you! You don't happen to know which size I need? Or maybe where did you get yours from?jreed wrote: 30 May 2023, 05:40 I had that concern too -- flexible thick wall silicone tubing worked. You can get a tight seal on the narrow end and still be able to stretch the tube over the larger fitting on the other side.
1997 Volvo 850 GLT Turbo - very small hose above lower radiator hose in engine bay is broken.
moses3
- Year and Model: 1997 850 GLT
- Has thanked: 68 times
- Been thanked: 5 times
Dorman makes a replacement rubber piece for this
https://www.amazon.com/Dorman-Help-4740 ... 146&sr=8-5
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
No idea on the size, but there are vendors on ebay selling various sizes of silicon hose by the foot. Also IPD sells it.moses3 wrote: 30 May 2023, 07:01Nice. Thank you! You don't happen to know which size I need? Or maybe where did you get yours from?jreed wrote: 30 May 2023, 05:40 I had that concern too -- flexible thick wall silicone tubing worked. You can get a tight seal on the narrow end and still be able to stretch the tube over the larger fitting on the other side.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
4 or 5 mm hose should work. I have both, but can't remember which I used most commonly. Measure the outer diam. of the line, substract 1mm and use that as hose ID and you should be fine.
850 T5-R '95 auto
moses3
Thank you, I already tried 5 and it's too big, I believe it's actually 3.5mm ID. It was a BMW hose size used by various automakers in the 80s & 90s. I imagine 4mm might also work.hausmeister wrote: 31 May 2023, 14:28 4 or 5 mm hose should work. I have both, but can't remember which I used most commonly. Measure the outer diam. of the line, substract 1mm and use that as hose ID and you should be fine.
hausmeister
Might be that It was 3 & 4 mm, my bad.
850 T5-R '95 auto
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I used some 3.5mm or 4mm silicone hose from Verocious motorsports.
https://www.verociousmotorsports.com/Sh ... y-the-foot
