2006 xc70 replacing one tire?
AlanS
Year and Model:
Post by AlanS »
One of my front tires has wear on the inner edge. I will get it aligned and evaluated. Is it ok to replace only one front tire? The other is in excellent condition.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
If it's AWD then you are stuck with buying 4 sets of tires every time regardless.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Alan -
They generally recommend against that, unless the replacement is the identical model and same tread depth.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
chris11211 wrote: 30 May 2023, 23:30 If it's AWD then you are stuck with buying 4 sets of tires every time regardless.
nah, that was only a problem on the earliest versions of awd.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Many eBay sellers list tread depth, so you should be able to find the same model and same tread depth for replacement.
08 C702.5T (sold)
The non-Swedes:
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Post by goldxc70 »
AlanS wrote: 30 May 2023, 22:15 One of my front tires has wear on the inner edge. I will get it aligned and evaluated. Is it ok to replace only one front tire? The other is in excellent condition.
Go to used tire place and look for identical model and wear tire as on other side. I've just had to do it and had a hard time finding one. Eventually I found a single tire with similar wear from same manufacturer, Michelin, but different model, Defender v Latitude.
If you don't have time to look around (I did), then just a pair as that's probably easier.
