1998 Volvo S70 Ignition Switch Screw sizes
WinDVD
- Year and Model: 1998 Volvo S70 Base
- Has thanked: 27 times
- Been thanked: 9 times
Hello all, I have a 98 S70 that needs the ignition switch bolted to the lock cylinder but I lost the bolts to it, Does anyone know what size bolts they are? I couldn't find any that fit at Lowe's but it would help if I knew the sizes to look for.
- Has thanked: 1611 times
- Been thanked: 4072 times
Do you seek the (1.) security screws that bolt the lock together or the (B) screws that hold the electrical part of the ignition switch to the steering column?
Ignition electrical bolt is a T25, probably a m6 thread
Shear bolts, see picture. Not sure what size those are
WinDVD
Hello, I mean the screws that hold the electrical part of the ignition switch to the column.abscate wrote: 01 Jun 2023, 03:03 Do you seek the (1.) security screws that bolt the lock together or the (B) screws that hold the electrical part of the ignition switch to the steering column?
Also m6 seems way too big for that and not even an M4 fit
- 13 Replies
- 2373 Views
Last post by JRev
- 781 Views
Last post by mecheng
- 2031 Views
Last post by DoggyB22
- 1563 Views
Last post by precopster
- 2830 Views
Last post by MrAl
