Name that rusty part
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Elsewhere on the Forum there is a 'torque chart' that specifies 35 ft/lbs for the oil pan drain plug. I would propose that is a tad too tight.
Has thanked: 2211 times
Been thanked: 1852 times
It is 35 Nm NOT 35 ft/lb.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 29 May 2023, 11:38 It is 35 Nm NOT 35 ft/lb.
When I was doing my timing belt, I was checking several sources. I even check the conversions in the Volvo documentation, as it's not always correct either. I found at least one spec, where the SAE and SI values were not equal to each other.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
That's fair. I work on that ft/lb = 75% Nm. It's very close. So your oil pan is 35 Nm = approx. 26-27 ft/lb. Don't want it tighter than that as you said or you crush the crush washer too much and remove the sealing properties!!
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
That oil pan plug was probably torqued to double the 35 Nm spec. I almost had to get out a breaker bar to remove it. It was brake caliper bracket bolt tight. No wonder the plug was wearing the crush washer like a second skin.
FireFox31
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 28 May 2023, 03:31 Here’s my entry for Sunday
Grunhilde? =P
I'm thinking oil filter bracket, at some point in its life.
2023 Lexus RZ450e -66k
Has thanked: 1611 times
Been thanked: 4075 times
Jreed for the win, it was a rear bumper bracket.
Bonus round, which side?
wizechatmgr
Driver's/left
FireFox31
Post by FireFox31 »
The notch is a giveaway on the bumper bracket. Are they are mirrored for each side? I'd say it's the right / passenger's side because I've seen two P80 rear bumpers retaining more water on the right side, ruining that bracket worse / faster than the left. Really makes me want to drill drain holes in the bumper metal. I think Robert DIY did that.
FireFox31
wizechatmgr
FireFox31 wrote: 31 May 2023, 15:12 The notch is a giveaway on the bumper bracket. Are they are mirrored for each side? I'd say it's the right / passenger's side because I've seen two P80 rear bumpers retaining more water on the right side, ruining that bracket worse / faster than the left. Really makes me want to drill drain holes in the bumper metal. I think Robert DIY did that.
It's funny you mention that, my rear right is precisely where my droop has started on my XC.
