10w40 is no problem in warmer weather. Check your manual, this came from my 08 S60 2.5T. 10w on cold start should be fine if above freezing.dikidera wrote: 06 Jun 2023, 05:12 I was running 5w30 oil before, but I plan to use 10w40. Thoughts on this?
Rust...in cylinders.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Absolutely no problem starting in the morning after ~5-10F (-15..10C) nights. Oil's pour point was -49F/-45C. Conventional oil may struggle, but I would walk away from conventional oil in any turbo engine.Krons wrote: 06 Jun 2023, 06:44 10w40 is no problem in warmer weather. Check your manual, this came from my 08 S60 2.5T. 10w on cold start should be fine if we’ll above freezing.
- Krons
Definitely synthetic. I’d give an extra minute or two to let the oil warm up though if it was below freezing.vtl wrote: 06 Jun 2023, 07:18Absolutely no problem starting in the morning after ~5-10F (-15..10C) nights. Oil's pour point was -49F/-45C. Conventional oil may struggle, but I would walk away from conventional oil in any turbo engine.Krons wrote: 06 Jun 2023, 06:44 10w40 is no problem in warmer weather. Check your manual, this came from my 08 S60 2.5T. 10w on cold start should be fine if we’ll above freezing.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 1611 times
- Been thanked: 4071 times
If that blue stuff sets hard it’s the wrong stuff. Get it off, and use Permatex 51813 or the Volvo stuff
- 953 Views
Last post by stephansvolvo
- 13 Replies
- 5035 Views
Last post by draser
- 41 Replies
- 14021 Views
Last post by Sweedy
- 1755 Views
Last post by freebirdchampion
- 848 Views
Last post by TylerW71
