Rust...in cylinders.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
dikidera wrote: 06 Jun 2023, 05:12 I was running 5w30 oil before, but I plan to use 10w40. Thoughts on this?
10w40 is no problem in warmer weather. Check your manual, this came from my 08 S60 2.5T. 10w on cold start should be fine if above freezing.
08 C702.5T (sold)
The non-Swedes:
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Krons wrote: 06 Jun 2023, 06:44 10w40 is no problem in warmer weather. Check your manual, this came from my 08 S60 2.5T. 10w on cold start should be fine if we’ll above freezing.
Absolutely no problem starting in the morning after ~5-10F (-15..10C) nights. Oil's pour point was -49F/-45C. Conventional oil may struggle, but I would walk away from conventional oil in any turbo engine.
Krons
Post by Krons »
vtl wrote: 06 Jun 2023, 07:18
Definitely synthetic. I’d give an extra minute or two to let the oil warm up though if it was below freezing.
08 C702.5T (sold)
The non-Swedes:
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I've torqued down the cam cover. Hope this sealant doesn't plug a oil passage.
dikidera
Post by dikidera »
I am sure I put down a small amount...yet it spit out.
vtl
Post by vtl »
That's why you supposed to use anaerobic sealant.
dikidera
Post by dikidera »
It's what I was given at a auto parts shop. I fully thought it was the correct thing.
vtl
Post by vtl »
As long as it's an anaerobic gasket maker you shouldn't have any problem with excess squished to the oil channels.
dikidera
Post by dikidera »
Has thanked: 1614 times
Been thanked: 4078 times
If that blue stuff sets hard it’s the wrong stuff. Get it off, and use Permatex 51813 or the Volvo stuff
