96 850 fuel leak with full tank
Has thanked: 2202 times
Been thanked: 1852 times
The car just keeps giving...........and not in a good way!!
The owners have just added that when the fill the fuel tank it leaks, but only when full. Now they only keep it at 3/4 or less.
What leaks on a P80 FWD fuel tank? Hoses, cracked pump plastic nut ring, leaking rubber seal? What else is up on top of the tank that leaks?
Thanks,
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Its known fault cracked breathing hose top of tank on these when aged. When i fill tip top it just comes out from there.
Others may correct me but this what i learned fron these. I have hose but still i havent changed it.
Been thanked: 4068 times
Open up the access port to check the top of pump. Dropping the tank on a FwD is easy once it is empty
NC855R
Year and Model: 1997 850 R
Has thanked: 46 times
Been thanked: 28 times
Post by NC855R »
Same here, was the top hose on the tank on mine. Would leak out after a fill up and stop after the tank level receded a bit. Following RobertDIYs instruction of drilling a hole to access one of the clamps.
xanthefin wrote: 06 Jun 2023, 23:38 Its known fault cracked breathing hose top of tank on these when aged. When i fill tip top it just comes out from there.
Thanks guys for your help. This was what I guessed and I'm going to get a camera up in there today for a quick look. That repair will have to go on the back burner and just not fill the tank all the way for a while. I have also seen the large black lock nut for the fuel pump crack and leaks from the seal gasket, but what you suggest sounds more likely.
I have not dropped a tank in a while on a FWD. My concerns on that is the joint is crusty at the tank for the fill pipe and I can't recall if you have to undo that to remove the tank or if you can drop the whole lot like on the AWD. I'll do some reading!!
Remove the spring clip, work the gaiter into the fender space, and drop tank and fill pipe together.
Thanks abscate. I do that with the AWD, but it has been 7 or 8 years since I did that on a FWD!
NC855R
Post by NC855R »
I did not drop the tank to replace the top hose. One side is pretty accessible to get the clamp off, the other side not so much, that is where the drilled hole comes into play to get a screwdriver on the clamp.
scot850 wrote: 07 Jun 2023, 10:21 Thanks guys for your help. This was what I guessed and I'm going to get a camera up in there today for a quick look. That repair will have to go on the back burner and just not fill the tank all the way for a while. I have also seen the large black lock nut for the fuel pump crack and leaks from the seal gasket, but what you suggest sounds more likely.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
This is what leaked on the top of the tank on the wife's car. (Also caused the perpetual P0455 code) Chewed up vent hose.
I stuffed my camera up there but not far enough. I may have to take the cover off and have a look with the camera from above.
Thanks Chuck!
