Name that rusty part
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Here's another entry in the Name That Rusty Part chapterbook that we're writing together, but this time to mix it up let's play one round of "Name That Dusty Part"...
- Has thanked: 2203 times
Hmm! I'm stuck on this one. Looks like a small heating coil of some sort. Is it on your 850 GLT? I can't see a fan impeller, or I might have guessed possibly the cabin temperature control behind the grab handles either side above the front doors?
But then there looks like water or oily substance around the plastic.
- jreed
You got it! First guess... Congrats!! It is the cabin temp sensor on the 97 855. The fan is there but hard to see in my photo of it. Super dusty and not turning (ECC code 414) until I brushed it off.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
No wonder these things need to be cleaned out. That is one tiny fan.
That is clean compared to some I have seen! This now makes me think I need to get out more......!
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Nice addition! The carpeting threw me off because I expect this on the dashboard to the right of the steering wheel like on a 2000.
FireFox31
- Been thanked: 4068 times
Moved to the roofline in the V70 model, 1998 in the Colonies
chillinied
- Year and Model: 1997 xc90 v8
Your lucky they didn't hit it with an impact wrench! My wife took the XC90 in for an oil change a few years back--and the next time I went to change it--it seemed like the plug was harder than usual to loosen. Upon installing the plug and going to tighten it--it broke free. Drained clean oil and found a darn heely coil! That was during covid--and to order a longer plug was a waste of time waiting. Saw good thread -just not at the start. Ended up cutting a bolt from the hardware- and then filing the threads clean--just need to hand tighten to get it started--which would have worked at the Valvoline shop if that jerk had tried it!
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 71 times
I figure I'll start with some easy ones:
Maybe this should be called "please figure out why":
This might be cheating but it's still something you could figure out:
And finally, guess what the seller described this rusty part carnage as in his description: (best viewed upside down...)
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
Number 3
- 4405 Views
Last post by 93Regina
- 1756 Views
Last post by oragex
- 713 Views
Last post by voom8
- 2358 Views
Last post by seanj
- 23 Replies
- 6338 Views
Last post by Phantomphixer
