How do you prevent rust on the holes in your license plate? My plates appear to be aluminum (non-magnetic, white corrosion) while my OEM license plate bracket and nuts are likely steel. Could that be causing dissimilar metal corrosion? I will likely get new brackets, stainless nuts, and rubber washers for both sides of the plate holes. But is it safe to use stainless nuts on regular steel bracket studs?
I want to repair the aluminum on my plates. What's a good adhesive to bond a new piece of sheet metal to the back side?
Yes, I post odd threads like this primarily to spark discussion which is more interesting than me doing solitary research online.
Preventing license plate rust and repairing a rusted plate
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
Galvanic corrosion caused by the different chemistry of the aluminium and steel bolts, aluminium being the softer it will oxidise quickest. I use 3M sticky tape for my plates to prevent this happening
Nylon washer from Lowe Quality and the m6 SS cap nuts from Belmetrics . Nasty corrosion, probably salt induced
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Cleaning vinegar should treat the damage. Maybe hit it with clear coat after, and a washer under the nut ?
The cap nuts that came with the blue-box bracket I put on one of mine years ago have held up pretty well, but another source for stainless is
https://www.boltdepot.com/Product-Detai ... oduct=7436
I've bought stuff from them, usually more than one item to offset shipping, it always arrives sooner than I thought possible.
- Has thanked: 311 times
- Been thanked: 817 times
Cap nuts from Volvo have always rusted for me. I use stainless m6 cap nuts and stainless m6 washers. Bought 100 of each many years ago from McMaster-Carr e.g. https://www.mcmaster.com/products/cap-n ... ess-steel/. Each car in the fleet has 8 of each, no corrosion.
RayF
- Year and Model: 2000 V70
- Been thanked: 7 times
FireFox, I'm afraid your only option for those license plates is this: Commit some fairly serious crime, then once sentenced to the state prison, get assigned to a prison job MAKING LICENSE PLATES. If you're a good obedient worker they might let you re-create those as a side project.
- 22 Replies
- 5288 Views
- 1212 Views
Last post by Paulo Costa
- 12 Replies
- 2486 Views
Last post by obayha
- 448 Views
Last post by DMike
- 2092 Views
Last post by oneon1
