07 XC70 driver's side blows warm air with A/C on Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Did you check the pressure to see if it was low on refrigerant charge yet?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
Incorrect charge can put a temp gradient on the evaporator and cause the side variation in temperature. BMW really sees this with a small charge loss.
- Has thanked: 311 times
- Been thanked: 817 times
Thanks for replies!
I did check low side pressure initially, before even posting. I it was like 27 so I wrote it off, thought it was about what i normally see on my P2's with this gauge. But I'll get a careful reading and report back.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
You need dual gauges for both low and high sides. Also a thermometer, high side pressure depends on the temperature. Once I got a dual gauges set, I'm able to fill the A/C on my own. Oh, I also got an A/C vacuum pump.
Noted, thank you. I'll check them both as I have a dual gauge set too. Harbor Freight but it works. Haven't splurged for a pump yet I have been borrowing one from FLAPS.
Engine warmed up, AC compressor running with fan on highest setting.
Permission to charge, captains?
Was checking psi as it charged and ended up finishing off the open can I had, about 8 oz (2/3 of a can) added overall. Definitely colder now on the driver's side so a big improvement but it still seems warmer than the passenger. We'll see how it holds up under demand. Readings are now 32/175 at 75 F.
Is it peculiar that the static pressure (engine running, AC not running) readings are not the same on low (65 PSI) and high (100 PSI) side? Seem too far apart to just reflect gauge (in)accuracy.
vtl
The high/low temperatures are different, so vapor pressure is different. But high side will eventually boil off and expand to the low side if left undisturbed.erikv11 wrote: 20 Jun 2023, 22:15 Is it peculiar that the static pressure (engine running, AC not running) readings are not the same on low (65 PSI) and high (100 PSI) side? Seem too far apart to just reflect gauge (in)accuracy.
- 8756 Views
Last post by dcm0123
- 18 Replies
- 8206 Views
Last post by packetfire
- 655 Views
Last post by phils94850
- 1278 Views
Last post by olddaddy
- 10 Replies
- 1747 Views
Last post by Ozark Lee
