ON A PREVIOUS POST, I SAW HOW A USER BUTCHERED HIS CAR IN ORDER TO GET TO THE J HOSE THAT OFTEN CRACKS AND CAUSES EVAP LEAKS/ CHECK ENGINE LIGHT TO TURN ON.
HERE ARE THE STEPS THAT NEED TO BE TAKEN IN ORDER TO REPLACE THE HOSE WITHOUT CUTTING HOLES IN YOUR FLOOR PAN.
I STILL CAN'T BELIVE THAT HE ACTUALLY POSTED THOSE PICTURES... BUT HEY THERE IS A WRONG WAY, AND A RIGHT WAY TO DO ANYTHING...
HERE ARE THE PICTURES FOR REFERANCE IF YOU WANT TO ACTUALLY DO THE JOB RIGHT AND IN LESS THEN AN HOUR OR 2.
WITHOUT A DREMEL OR A TORCH!
YOU SIMPLY HAVE TO TAKE DOWN THE REAR SECTION OF THE EXUAST, REMOVE THE CHARCOAL CANISTER, REPLACE THE HOSE AND REINSTALL IT. LIKE A NORMAL HUMAN BEING...
HAVE A GREAT DAY!
VOLVO FOR LIFE
P.S.
NOT SURE WHY THE PICTURES SHOW SIDEWAYS, BUT YOU GET THE IDEA...
XC70 2001 Evap J hose RR
VOLVOTK427
- Year and Model: 2001 xc70
- Been thanked: 4 times
Reason: Removed caps from titie to reduce noise levels
- Has thanked: 1611 times
- Been thanked: 4071 times
That’s totally LA!YOU SIMPLY HAVE TO TAKE DOWN THE REAR SECTION OF THE EXUAST,
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
This post really ticks all the boxes.
All caps
Wrong orientation on pictures
No real “steps” just slamming another poster’s method
10/10 for the most stereotypical auto forum post I’ve ever seen in my life. Love it.
On second scroll through photos: canister really just magically slides out towards you? I find it hard to believe the rear access of that assembly is that easy.
All caps
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
YOUR LACK OF UNDERBODY RUST IS OFFENSIVE. NO WONDER YOU HATE BUTCHERS.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 2207 times
Thanks for sharing the correct way to tackle this job. Like the guys say, it is great to see the underside of a car without all the rust from the winter de-icing products on the roads here.
I did the first step and and installed a hoist..........!
Now for the rest!
Now for the rest!
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Thank you!VOLVOTK427 wrote: 13 Jun 2023, 12:09 YOU SIMPLY HAVE TO TAKE DOWN THE REAR SECTION OF THE EXUAST, REMOVE THE CHARCOAL CANISTER, REPLACE THE HOSE AND REINSTALL IT. LIKE A NORMAL HUMAN BEING...
Does the pump fail, item #6; does VIDA show the status of this item? A vacuum test if it is out?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Please remind the rest of us what system the J hose is connected to?
xHeart
The J hose #26 connects EVAP canitster to the pump; item #6 shown in the diagram. Fuel Evaporation Shut Off Valve https://www.fcpeuro.com/products/volvo- ... 70-9486016BlackBart wrote: 22 Jun 2023, 10:35 Please remind the rest of us what system the J hose is connected to?
- BlackBart
Thanks. So all XC70s have this system? I should take a look under there. Is this a common problem? Is it a high mileage thing?
- 13 Replies
- 6914 Views
Last post by VolvoBoron
- 147 Views
Last post by cn90
- 936 Views
Last post by darrylrobert
- 411 Views
Last post by Vova585
- 1109 Views
Last post by JRL
