when 4C struts are dead
Has thanked: 1836 times
Been thanked: 1709 times
Re: when 4C struts are dead
I did the fronts on our 06 XC70 with 4C front shocks. I chickened out on the rears and got the dealer to do them as there was a broken spring as well. Unless the dealer used Vida, I never did on the fronts.
Has thanked: 292 times
Been thanked: 765 times
Fronts are a cakewalk, almost not difference from non-4C.
Rears are a nightmare! The access seems ridiculously difficult.
Let us know how it goes!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
YV1LW
Year and Model: 98V70r
Has thanked: 15 times
Been thanked: 4 times
Post by YV1LW »
Waited for a heat wave to start the project. Anyone wanna know the gory details??
Yeah!
Did you get it done? How was it?
'06 S60 R, 197k
Has thanked: 1497 times
Been thanked: 3810 times
I need to read uplifting success stories to motivate my valve job redo
YV1LW
Post by YV1LW »
Having just completed the process of removing & installing new Monroe C1501S struts. Frankly, I would have gladly paid twice for the struts if the install engineering had been easier. Of all the PITA tasks, the most frustrating was removing the female connector from the male connector that is hidden and almost unreachable by an ordinary human being.
About midway thru the process I did realize, finally, removing the spring & strut assembly allows a small amount of access to the connectors attached to the rear sub-frame from above the axle & disc brake. What was most helpful was an thin, 8"  long slot blade screwdriver to pull the locking tab toward the center of the connector assembly. Once that is released, removing the strut connector is a comparative breeze. I think a 10" screwdriver would be an easier reach into the nether world Volvo created for anchoring the connector receiver.
It helped somewhat to have a video camera with an end light and 3' flexible scope to peer into the area where hands can barely squeeze.
An unappreciated issue is the force required to pull the suspension down. While VIDA instructions make the use of a ratchet & strap seem like an easy proposition; I found that anything less than 1.5" wide was just not able to create the pulling force required. I ended up with 1.5" strap and still found the use of a long 2x3 and a block to persuade the suspension down helped get more tension on the components
It took me some experimentation to learn how to use the spring compression set I had purchased. At the conclusion of the process, I realized that a shorter and less complex spring compression tool is more useful in compressing the springs in the confined area of the chassis, aiding in the removal of the strut assembly, and in the installation of the strut Support Plate(s) (8646101).
The proper alignment of the spring seat (30748888) is crucial to getting the entire assembly correctly orientated for easy re-installation. I found the more marks and alignment points I created made for an easier reorientation of the spring, spring seat & strut assembly. My first attempt was just barely passable, but the use of multiple reference points made installing the second spring seat less of a challenge trying to position the spring properly in relation to the shock mount anchorage (8250447/48).
The flange bolt listed as item #2 (989035) in most parts manuals; at least for my vehicle, is incorrect. The bolt requires an integral washer. If I was to replace another set of struts, I would order a few extra Hood Lift Support Clip (9470602) for reattaching the new signal cables to the chassis.
When I got the old struts out, the bottom of the assembly was wet with strut fluid and dirt; the dampening action of the struts was next to nil and I understand why the car felt as if it would leave the road of it's own quixotic decision.
A labor and frustration reducing tool could be a strut bolt socket. Kobalt makes a set with a ratchet that looks like it would make the strut nut removal, with a long T-40 Torx bit, much quicker with less frustration. I ended up using an 18mm impact socket that had a single hole drilled in the side along with a spanner wrench to remove & reinstall the strut retaining bolt.
If there is a next time, I think I might be able to get the process (not including the VIDA SUM re-calibration) completed in 6 hours. First time around I'm estimating I had 12 hours spread over 3 days.
Monroe C1501, the 4C rear shocks, are currently $187 each at RockAuto. With tax and shipping and the usual 5% discount code, that's under $400 to your doorstep for the pair.
'06 S60 R, 197k
YV1LW
Post by YV1LW »
pricing 22jun23 is now $198.79
Still a smokin' good price!
Mine showed $199 yesterday, then today I reloaded the car and it showed $187 so I clicked buy. And no, I wasn't getting fooled by the 5%, that was later discounted on top.
'06 S60 R, 197k
Do you have a place in the garage for them to report back where they are next year?
