XC70 2001 Evap J hose RR
VOLVOTK427
Year and Model: 2001 xc70
Been thanked: 4 times
Post by VOLVOTK427 »
ON A PREVIOUS POST, I SAW HOW A USER BUTCHERED HIS CAR IN ORDER TO GET TO THE J HOSE THAT OFTEN CRACKS AND CAUSES EVAP LEAKS/ CHECK ENGINE LIGHT TO TURN ON.
HERE ARE THE STEPS THAT NEED TO BE TAKEN IN ORDER TO REPLACE THE HOSE WITHOUT CUTTING HOLES IN YOUR FLOOR PAN.
I STILL CAN'T BELIVE THAT HE ACTUALLY POSTED THOSE PICTURES... BUT HEY THERE IS A WRONG WAY, AND A RIGHT WAY TO DO ANYTHING...
HERE ARE THE PICTURES FOR REFERANCE IF YOU WANT TO ACTUALLY DO THE JOB RIGHT AND IN LESS THEN AN HOUR OR 2.
WITHOUT A DREMEL OR A TORCH!
YOU SIMPLY HAVE TO TAKE DOWN THE REAR SECTION OF THE EXUAST, REMOVE THE CHARCOAL CANISTER, REPLACE THE HOSE AND REINSTALL IT. LIKE A NORMAL HUMAN BEING...
HAVE A GREAT DAY!
VOLVO FOR LIFE
P.S.
NOT SURE WHY THE PICTURES SHOW SIDEWAYS, BUT YOU GET THE IDEA...
Reason: Removed caps from titie to reduce noise levels
Has thanked: 1609 times
Been thanked: 4065 times
That’s totally LA!
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
This post really ticks all the boxes.
All caps
Wrong orientation on pictures
No real “steps” just slamming another poster’s method
10/10 for the most stereotypical auto forum post I’ve ever seen in my life. Love it.
On second scroll through photos: canister really just magically slides out towards you? I find it hard to believe the rear access of that assembly is that easy.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Step 1. Install a lift.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
YOUR LACK OF UNDERBODY RUST IS OFFENSIVE. NO WONDER YOU HATE BUTCHERS.
:lol:
08 C702.5T (sold)
The non-Swedes:
Has thanked: 2198 times
Been thanked: 1851 times
Thanks for sharing the correct way to tackle this job. Like the guys say, it is great to see the underside of a car without all the rust from the winter de-icing products on the roads here.
I did the first step and and installed a hoist..........! :D
Now for the rest! :lol:
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
VOLVOTK427 wrote: 13 Jun 2023, 12:09 YOU SIMPLY HAVE TO TAKE DOWN THE REAR SECTION OF THE EXUAST, REMOVE THE CHARCOAL CANISTER, REPLACE THE HOSE AND REINSTALL IT. LIKE A NORMAL HUMAN BEING...
Thank you!
Does the pump fail, item #6; does VIDA show the status of this item? A vacuum test if it is out?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Please remind the rest of us what system the J hose is connected to?
xHeart
Post by xHeart »
BlackBart wrote: 22 Jun 2023, 10:35 Please remind the rest of us what system the J hose is connected to?
The J hose #26 connects EVAP canitster to the pump; item #6 shown in the diagram. Fuel Evaporation Shut Off Valve https://www.fcpeuro.com/products/volvo- ... 70-9486016
BlackBart
Post by BlackBart »
Thanks. So all XC70s have this system? I should take a look under there. Is this a common problem? Is it a high mileage thing?
