Oh right, ha!wizechatmgr wrote: 28 Jun 2023, 05:54With the amount he drives? If they don't go ready, they never will! =)
Changing Battery, OBD2 Battery Keeper 1998 v70
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Make sure key isn't left in ignition - I know, it sounds obvious... We had an experiment a while ago where if the chip for the key is left present, some modules won't turn off or will and then turn themselves on intermittently. Doesn't matter the key position either. Mere presence of the chip does it if I remember correctly.MrAl wrote: 27 Jun 2023, 15:06 Hi,
Very good catch. Those bulbs could draw 500ma each and there are several. That would put a strain on the wiring.
I guess we have to keep the doors shut.
Anything else you think might draw current?
2023 Lexus RZ450e -66k
- Has thanked: 1611 times
- Been thanked: 4072 times
There is even a P code for “key left in too long “ which pends when you do the key/antenna trick on a 1999 immobilizer.
My recollection on the 1999 is the OBD power buss is through the CDM (or DDM as it’s also called ) so generally that won’t back feed to the ECU supply.
I would just 12 volt to the kidney fuse box bolt and a ground
It’s not trivial to remove the battery and keep 12 volt on the bus but it’s possible; I had to do it on Shagg once for inspection , to swap batteries
- MrAl
Hi,wizechatmgr wrote: 28 Jun 2023, 06:00Make sure key isn't left in ignition - I know, it sounds obvious... We had an experiment a while ago where if the chip for the key is left present, some modules won't turn off or will and then turn themselves on intermittently. Doesn't matter the key position either. Mere presence of the chip does it if I remember correctly.MrAl wrote: 27 Jun 2023, 15:06 Hi,
Mine doesn't have a chip in the key but I'll do that anyway. I usually remove the key every time I get out of the car. Rare times when I leave it in on purpose like when I have to keep the engine running and get out for something.
- MrAl
Hello Steve,abscate wrote: 28 Jun 2023, 06:33 There is even a P code for “key left in too long “ which pends when you do the key/antenna trick on a 1999 immobilizer.
Thanks, but i am not sure what the kidney fuse box bolt is or where it is.
Before that advice i planned to bolt wires right to the lead connectors on the battery, and as i remove each one put a glove and rubber band around so neither terminal can touch anything while the battery is being removed and installed.
Did you see the bolts on my Volvo connectors for the battery? They are not the bolts you use to tighten the terminals to the battery, they are different bolts that stick up from the terminals. I used them to bolt wires from the solar panel directly to the battery terminals with only a fuse inline. I was thinking maybe that is what they are there for? They must be for something.
I'll post another pic of the battery terminals on this car.
I like your idea too though.
- MrAl
Here is the pic of one of the studs on the battery terminals.
Easy to bolt wire right to those studs.
Pin 16 on the OBD should work for 12Vnto battery
Use pin 4 or 5 for ground
- 653 Views
Last post by EngineeringBloke
- 1246 Views
Last post by MrAl
- 583 Views
Last post by doa202
- 3864 Views
Last post by vtl
- 640 Views
Last post by Ozark Lee
