'06 S60R Automatic Transmission: Where is the FILL plug?
Ethan5150
- Year and Model: 1994 850 Turbo
- Been thanked: 2 times
Can someone tell me where the fill plug is located on the '06 S60R automatic transmission? A picture would be awesome but I realize that's a lot of work... If anyone could point me in the right direction that would be most appreciated!
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Pretty sure the Rs have the same yellow dipstick as other P2s, buried in the center of the engine bay on the transmission. May be easier to see from underneath.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Is it 5 or 6 speed?Ethan5150 wrote: 05 Jul 2023, 20:01 Can someone tell me where the fill plug is located on the '06 S60R automatic transmission? A picture would be awesome but I realize that's a lot of work... If anyone could point me in the right direction that would be most appreciated!![]()
- Has thanked: 311 times
- Been thanked: 817 times
06 S60R has TF-80SC transmission, 6 speed. Second video is spot on for where/how on the drain plugs and the full plug, and how to properly fill and check level by getting the gearbox up to temp.
Your call if you want to do drain/fill or flush, I have always done flush. Some good stuff in this thread, but some fluff too: https://www.swedespeed.com/threads/tran ... ic.226398/
KurtL
- Year and Model: V70R 2005
- Been thanked: 5 times
The dipstick is in the same place as the regular P2 wagons. I pull my airbox on the 05 V70R to get to the dipstick/fill hole when doing a drain and fill. I didn't have to do this to my 01 V70.
Ethan5150
Thanks for all the support guys - I purchased the vehicle after the owner sent me a video of some good clean-looking trans fluid. I'll probably do the drain-and-fill method for the next several oil changes. Really appreciate your support!
There is no dipstick in an 06 or 07 P2 R, unlike the 05 and earlier ones. The TF80-SC transmission does not have a dipstick.
Warning..many of these transmissions have a bolt on top that looks like a fill plug, if you remove it you need to disassemble the transmission to put bands back in place , or a skilled person to do an in-car โ bandcaptureโ
- 2071 Views
Last post by polskamafia mjl
- 2868 Views
Last post by Archer
- 10 Replies
- 3877 Views
Last post by Blacklab467
- 496 Views
Last post by Ethan5150
- 480 Views
Last post by m96ag
