Weak orange spark 1995 850 2,0 10V
Kokonradus
Year and Model: 1995 850 10v GLE
Has thanked: 14 times
Post by Kokonradus »
Hello, I am testing spark and on every cylinder the spark is bit weak, like on the photo:
Snímka obrazovky 2023-07-09 215516.png (447.05 KiB) Viewed 652 times
Changed spark plgus, wires, cap and rotor, ignition coil, but the spark stays the same. (all the parts replaced have proper OEM number, all are Bosch brand).
What should I check next? Maybe a relay under the fuse box, or wiring connections? I suppose there is problem somwhere in power supply to the coil. Has anyone else problem like this?
Thank you a lot for help :)
1995 Volvo 850 2,0 10v NA - Wagon
1996 Volvo 850 2,5 20v NA - Wagon
1992 Škoda Forman 1,3 Carburetor
2004 Volvo Xc70 D5 AWD (Sold)
1998 Škoda Felicia 1,9D LAURINA (Sold)
Has thanked: 2200 times
Been thanked: 1852 times
Does the car start and run, or is that the problem and why you are asking about the spark color?
Kokonradus
Yes, the car starts and idles. But performance is not as it should be, there are some misfires and unburnt gas in exhaust and oil. Bad fuel economy of course. Sometimes the lambda light turns on and code 1-1-3 is thrown (short term fuel mixture is too weak).
Car had this code all the time and had bad backfires - replaced O2 sensor - backfires and permanent lambda light disappeared
Car had really bad long and painfull starting - changed fuel pump and FPR - now it starts right up
Car smoked like old TDI with rich mixture - changed ECT sensor, problem presists - changed ECT sensor connector - problems are gone
Car still had a rough idle - replaced whole PCV system and detected and fixed all vacuum leaks
With all these problems the car barelly starts and runs at all.
Anyway these side stuff has nothing to do with spark and ignition. Maybe I should mention I´ve replaced crank position sensor and cam position sensor and the spark remained like this. Also I tried three other types of spark plugs I found but the spark stays the same weak and orange yellowish...
Yesterday I studied 1995 fenix 5,2 electrical diagrams and It seems the + circuit goes from key ignition through the 40A fuse to Overload relay +15 (the middle 106 relay). Finally it goes to ignition power stage and coil 15 contact. Frequency of spark seems to be controlled with ground leading directly from ECU to power stage. Simillar as on the fuel injectors.
Been thanked: 4065 times
That is a weak looking spark but you seem to have covered all the suspects. Are you trying three prong plugs for the 10V
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
How is compression test results? Or did i miss it...
Kokonradus
No I have not tried the three prong plugs. But I tested the spark on a four prong plugs, here is result:
Snímka obrazovky 2023-07-10 140156.png (1.11 MiB) Viewed 589 times
Compression numbers are 155-175psi (should be 180-210 for N/A models)
Wet compression test is 210 on all cylinders (worn out piston rings)
Which spark plugs would you recommand for this cars?
I am working on it right now and I changed overload relay 15+ and 40A fuse, cleaned all the contacts on connector to power stage but the spark is remaining the same. Actually don´t know what to do now :D mystery...
Kokonradus
Is there a tool that measures relevant numbers of ignition coil output? Really have no clue now how to continue with solving this spark issue.
xanthefin
Post by xanthefin »
As there was fuel pump problems.. Does injectors spray okay or any leaking one?
Kokonradus
Yes injectors are working fine.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
If you haven't already, it might be a helpful to measure the voltage on the primary (low voltage) side of the coil to see if it's good. I would expect it to be > 12.6V with the car running.
Also, it would be a good idea to check the engine grounds and battery ground cables are good, with low voltage drop (< 0.1 to 0.2 V) across them with the car running.
