Uneven tire wear.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Both of my rear tires look like this:
The right tire (not shown) looks to be worn in that part slightly less.
What causes this problem? Does the car just need an alignment, or is it a suspension issue?
It's also possible that these tires used to be on the front of the car but were rotated. The front tires do not have any unusual wear.
2002 v70 X/C 288k miles
Has thanked: 2200 times
Been thanked: 1852 times
If these were on the front, do any of the inner and outer tie rods look recent? Could be the tie rod(s) were replaced and the issue corrected but the tires were not replaced. Those tires should be replaced now!
These cars have 4 wheel alignment. If you are not sure, an alignment would highlight any issues assuming you can find a good shop.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
jonesg
Post by jonesg »
He got the rear alignment fixed with a new track bar..
Evan isn't a volvo mechanic, he does things differently than we do but it works.
On my car the front drop links were bent from an accident before I bought it, the shop said it couldn't be aligned , no suggestions , I found the bent drop links after pulling one off to inspect. I still have rear drop links to install but the kettles boiling so.....
