Hello there,
I have not used the key fob in something like four years. Back then it worked fine, and it probably still does I just have to test it tomorrow.
What I was wondering is, if the little internal battery went dead and I take it apart and replace the battery, will it still be "paired" with my Volvo?
Keep in mind it was fine last time I used it. I'm just worried that if I change the battery I might have to do some kind of sequence to get it paired with my actual Volvo again so it works the doors again and all that stuff.
Thanks for any information about this.
(Simple + i * Simple) Key Fob Question 1998 v70
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Search for pairing fobs in this Forum. It’s covered
Usual
-1998 procedure
1999- procedure
Usual
-1998 procedure
1999- procedure
- MrAl
Ok thanks.abscate wrote: 13 Jul 2023, 18:58 Search for pairing fobs in this Forum. It’s covered
Usual
-1998 procedure
1999- procedure
BTW, did you get my PM about the optics question?
Ill be testing the key fob today.
- MrAl
Usual
-1998 procedure
1999- procedure
I found info on this forum that states you just keep clicking the fob to pair, but that can't be right, or anyone can walk up to the car and pair with it. Maybe the ignition has to be on too?
- MrAl
Hi,
That would be nice.
- MrAl
Hi,
What about if the car battery went dead and you took it out by disconnecting it completely, then put a new battery in the car.
Do you need to pair again after that?
I ask because that happened too.
- Has thanked: 2199 times
You should not need to pair the fob as mentioned. Otherwise we would all be doing this on a regular basis.
As also mentioned, the same with the fob.
- MrAl
Hi there Neil,scot850 wrote: 14 Jul 2023, 10:14 You should not need to pair the fob as mentioned. Otherwise we would all be doing this on a regular basis.
Oh great thanks.
I found out the battery in the fob was dead, 70mv, so I had to order a couple CR2016 cells.
I had CR2032 cells but they are twice as thick and so don't fit in the fob.
Test Sunday or Monday.
- MrAl
Hello again,
Ok got the new batteries today and just tested it a little while ago. It still works, hurray.
Have to be a little careful how you put the battery in though, make sure it touches both side contacts first then press down gently.
