And no, you can't replace the top spring seat without removing the complete strut.
Sway bar/end link noise?
- Has thanked: 2199 times
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
I had my sister video record the top of the strut while I was turning the steering wheel to the left. See below:
Movement of the strut top was hardly noticeable.
Now, I have the steering wheel turned all the way to the left and the car will not move when I shift into drive or reverse. When I begin to straighten the wheel, the car will move forward/backward.
Could there be something on the rack that is preventing movement when the wheel is turned all the way to the left?
Tomorrow, I will raise the front end and remove the tire so I can hopefully see what the problem is.
Is there is bump stop of some sort on the rack so the wheel only goes so far in either direction?
Appreciate your thoughts on this!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
There is a limit stop arm on the front of the knuckle, and that should be limited in it's travel by a nylon pad on it the leading edge of the lower control arm that acts as the limit stop.
That spring seat is really bad. One pothole away from waving to you through the hood!
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
The fact that the strut mount is shedding rubber is diagnostic for replacing the mount. If the strut cylinders aren't leaking and the car doesn't misbehave while cornering and such - that is, if the only issue is the clunking - then just replacing the mount is budget friendly doing the work yourself. Paying a shop to do the work means they have to touch all the pieces anyway, so think about refreshing the struts themselves (especially if this is the car with 260k and the struts are original.)5rivers wrote: 17 Jul 2023, 19:46
The range of motion is limited by a protrusion extending from the base of the steering knuckle making contact with a hard plastic pad on the lower control arm.
5rivers
Well, I was able to take a closer look at the inside of the rim and determine where it is rubbing. At first I thought it was the bleeder screw - had to replace not long ago, but it's longer than the original one in the caliper. When I had the wheel turned all the way to the left, the rim seemed like it was making contact with the top outer part of the caliper.
I made a slight adjustment to the inner tie rod and that seemed to increase the clearance. But, after straightening out the front wheels, I looked again inside the rim. There was a definite line of coating missing all the way around the rim. Initially I thought maybe its the lower part of the knuckle (the arm that sticks out) with the plastic bump stop. But it wasn't that. I did find some of the rim coating on the part of the strut that sticks out just above the upper bolt securing it to the knuckle.
I am now wondering if there needs to be more adjustment to the tie rods - more toe in, maybe? that would bring the lower part of the wheel in, and the upper part out, if I am correct. Trying to make enough of an adjustment to be able to drive the car to a shop for a wheel alignment.
Appreciate your thoughts!
I have not forgotten about the strut...and its possible role in the tire rubbing scenario.
5rivers
Can you post picture(s). I had a problem once and it was with 15" wheels and the balance weights catching on the caliper. Those stick on ones.
5rivers
There are 15" wheels on the car.
I'll post pictures tomorrow.
5rivers
So check if there are any residues of the sticky tape that holds stick on balance weights or even weights still there. I used to have regular knock on weights on the inside of 15" wheels for that reason.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I honestly can't believe Volvo offered 15 inch rims on these cars. There is very, very little clearance to the caliper with a healthy suspension.
Not much sense in getting an alignment, as it sounds like you have multiple worn suspension components left to sort out first.
Knows enough to be dangerous
5rivers
The car came to me with 15 inch steel rims that I replaced with a set of 15" alloy rims. I did inquire here about that and if there were going to be issues, and at the time, it didn't appear to be a problem...only that the speedometer would be reflecting a slightly slower speed.
Shortly, I'll post pictures of the rim in question.
I'll start searching for 16" rims and tires...
5rivers
- 14 Replies
- 3386 Views
Last post by subzerocarfanatic
- 22 Replies
- 4979 Views
Last post by jonesg
- 34 Replies
- 9316 Views
Last post by E Showell
- 849 Views
Last post by FCPEURO
- 1443 Views
