Diagnose the issue anyone?
Has thanked: 311 times
Been thanked: 817 times
I didn’t mention this earlier in the thread because it didn’t fit the order of what I checked but Neil and now Chuck too for the win: when it got really bad I finally checked fuel pressure, steady 15 psi.
Swapped fuel filter, no change. Fortunately I have a couple spare fuel pumps from the junkyard. So I pulled the fuel pump.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Feed line clamp from pump to housing got loose ...or short in that wiring?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Been thanked: 4065 times
Lets take a look for a bright blue spark at a plug grounded to the top of the head to rule out an aging coil. Those can go wonky on you as a function of time and temperature.
Oh my.
Time to break out the
OETIKERS!!!!
Neil/Chuck for the win...
+1 on the above, but also check fuel pressure
MVS Volvo Horns.jpg (34.19 KiB) Viewed 396 times
Has thanked: 2200 times
Been thanked: 1852 times
+ 1 to Chucks great suggestion of smoke tester. Save a lot of crawling about and random searching if it is pressure or vacuum related.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
erikv11 wrote: 20 Jul 2023, 11:08 IMG_3294.jpeg
I ran into this SAME issue on the '96 GLT I had. It would just randomly run rough and want to die, no power, etc. Other times run great.
Found this when I pulled the pump.
I was going to suggest this earlier, because it sounded just like my problem. (I blame being busy at work trying to fix a work machine problem)
Is that the correct clamp type? Oetiker would work better than that or a proper fuel pipe clamp.
misha
Post by misha »
That's a factory clamp.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The Kat has trained me on connecting rubber hoses to straight pipes
Roughen , flare end, use glue on the bond.
