Diagnose the issue anyone?
Has thanked: 312 times
Been thanked: 818 times
yep same thing in Chuck’s pic, loose feed line. That screw clamp is cinched completely tight from the factory but on most aging pumps you can just spin it, definitely a poor choice they should have used a smaller diameter clamp.
I fixed it by installing about 4 inches of new hose where the original was just under 3-1/4”. But I did use the same clamp! You have to use submersible fuel line it’s like $20/foot, I had a piece left over from a previous fuel pump repair when I bought the Bosch insert for my wagon’s pump.
Has thanked: 1613 times
Been thanked: 4075 times
Can you get into the pump enough to swage on a small flare onto the nipple end? It should really have that. Straight connectinghose onto bare pipe at 50 psi pressure is problematic
Is gates Barricade Fi hose ok to use here? I wouldn’t have checked for submersibility
, Q: Can Barricade hose be submersed in gasoline?
A: NO. For fuel line hose that will be submersed in gasoline, use Gates Submersible Fuel Line Hose which is specially engineered for constant contact with gasoline (and other liquid petroleum distillates) on the inside and the outside.
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 55 times
Been thanked: 28 times
Post by SOURDOUGHJIM »
Abscate, I did not know that. I have put that bit of knowledge into the memory bank. Unfortunately, at my age, when a piece of info gets inserted in the front, other info gets pushed out the back. I wonder what I just lost....
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
abscate wrote: 21 Jul 2023, 01:53 Is gates Barricade Fi hose ok to use here? I wouldn’t have checked for submersibility
Yeah, I dug into it. Looks like a "T10" or a "T14" spec is needed for submersibility. The submersible stuff does specifically say so and is usually printed on the hose itself and the cost also reflects the capabilities.
Crap, $20 a foot.
It’s another opportunity to buy this in bulk and mail out the required 6 inches to those in need
Yeah, $20/foot is probably why they cheap out on it from the factory, even though of course the manufacturer is paying much less.
Top is the factory piece I removed that was dislodged you can see it’s just under 3-1/4” long. Bottom is the remaining piece I have of the unused submersible line after buying 12 inches and doing two P80 fuel pump jobs. Looks like I am using 4” pieces I’ll edit my post above to reflect that. The 5/16 is a very tight fit on the pipe, fwiw.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Abscate, can you show us the tool that flares that pipe?
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
SOURDOUGHJIM wrote: 21 Jul 2023, 05:23 Abscate, I did not know that. I have put that bit of knowledge into the memory bank. Unfortunately, at my age, when a piece of info gets inserted in the front, other info gets pushed out the back. I wonder what I just lost....
Don't worry, it's already gone and you can relearn it another day ...
1996 855 R,
2010 V70 D5,
Submersible fuel line $50 for 5 feet
https://www.amazon.com/dp/B0C1YH5GKR/re ... 9kZXRhaWwy
