Just noticed this after stopping for gas on the highway. Is this safe to take another 200km or should I return to home base!
Driver side bolt gone
08 s60
SOLVED wheel bearing bolt gone in middle of nowhere Topic is solved
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I cannot tell you its ok to drive like this, the inner CV joint is retained by a circlip so it will not come out of the transmission. If I had to move a vehicle that's missing the bolt on the outside of the CV shaft I would certainly minimize turn radius', particularly at speed. I would probably do it.
2003 XC 70 (sold)
yanga001
Made it over safe and sound. Will get my Indy to replace in the morning. I think that bearing was bad anyways so no I’ll effects as other said. I was getting abs issues on that side at one point and wonder if this had anything to do with it :/.
I recall watching my Indy take these apart before and know there is a bolt at the bottom that holds the hub in the strut. Point being it won’t come out I believe.
yanga001
Just spoke to my indy and he said that the bolt missing can cause ABS errors to occur before i mentioned ABS issues happening so i guess that confirms my suspicion. Will get the new bolt in with a few other items.
