04 v70 tailgate open Topic is solved
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
but its not open.
Where is the sensor or switch. ?
This might be related to broken rear glass I had fixed last week.
Maybe the repair guy disturbed something or glass got in the hatch panel.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
It is in the door lock itself. You may have a pinched wire, they are prone doing so around the hinge.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
jonesg wrote: 04 Aug 2023, 05:35 but its not open.
It may be related to the rear glass. Some cars, not mine, route the wire that's grounded when the tailgate is closed through a wire film on the rear window to detect window breakage and set off the alarm. Most of the time the tailgate open problem is due to broken wires in the left hinge area but in your case in may be the window(7/137). When the tailgate is closed a micro-switch in the tailgate latch(3/78) closes and grounds the wire to tell the CEM the tailgate is closed. In either case I think you're going to have remove the upper rear trim to get access to the wires in the left hinge area (54/50 connector). Locate the pink wire and check for any damage and also measure to ground when the tailgate is closed, should be grounded. You might just be able to see a problem with the window wire film.
Rear tailgate closed wire path.jpg (94 KiB) Viewed 590 times
jonesg
Post by jonesg »
window heater wire sounds likely, that was the scene of the repair.
firstv70volvo
jonesg wrote: 04 Aug 2023, 12:08 window heater wire sounds likely, that was the scene of the repair.
I don't think the rear window heater is part of the tailgate closed wire path. There should be a separate wire film pattern on the rear window with a different set of wires going to it, the pink wire from the 54/50 connector and a black wire from the same connector. The rear heater resistor film pattern has a red and black wire going to it.
jonesg
Post by jonesg »
ok, thanks, its a hard rain falling here, cant use the garage yet so it can wait.
jonesg
Post by jonesg »
firstv70volvo wrote: 04 Aug 2023, 14:30
as I suspected , bad glass installation.
The glass guy broke one of the elec tabs or they delivered it already broken , he installed the glass and just shipped it down the road.
Safe to say the rear defogger probably doesn't work either....missing the main ground connection.
Eric of main st auto solders them back in place, I don't have the tab, i'll try to solder a wire directly to the pad on the glass using tinned marine wire.
EDIT:, that fixed it, no more warning triangle.
