Help diagnosing bad engine sound *solved* Topic is solved
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 8 times
Post by greffel »
Thanks for your fast reply vtl
You are right, its just that the engine has brand new oil in it that I don't want to waste :)
If we remove the pan and don*t see any signs of overheat or play in the rod bearings then there is no point in takin them apart ?
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
You can inspect rod bearings once the pan is out, it's not that difficult. Pan removal/installation is more laborious process anyways.
You can also push on crankshaft at the ends to feel it has any sign of slack. That would be really bad, likely the end of the engine.
Also collect and reuse the oil if you want. Maybe filter it before pouring back.
greffel
Post by greffel »
This evenings findings:
1. We changed the gearbox 1,5 years ago and now when the pan is off the car I could easy feel the bolts between the flywheel and torque converter. They where all loose :roll: and now I'm hoping this could have been the rattle from my engine.
2. The rod bearings have all play side to side and feels really smooth, no play at all up and down. This must be a good thing ?
Did also check for play in the crankshaft side to side, but there is no visual play at all.
The pan will enjoy a soaking bath in machine cleaning detergent.
365989393_9715062445234505_2948992375762769612_n.mp4
(5.95 MiB) Downloaded 153 times
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
That's good news, I expect thats the cause of your horrible engine sound. I had a Corvair years ago that had a very small crack in the flywheel and it made the engine sound like it was coming apart, similar to yours. How long did it take you to get the oil pan off?
2003 XC 70 (sold)
Has thanked: 2212 times
Been thanked: 1852 times
Eek that pan is filthy! Good clean of that and the pick up, new sealant and good to go.
Your gut was pointing to the torque converter all along, so good diagnosis.
Does the P2 5 cylinder not have the 'O' ring seals to the head that the P80's do?
vtl
Post by vtl »
scot850 wrote: 11 Aug 2023, 17:19 Does the P2 5 cylinder not have the 'O' ring seals to the head that the P80's do?
O-rings where? Between the block and the head? No.
Geraldt
Year and Model: S60 2.5t AWD 2003
Post by Geraldt »
Blacklab467 wrote: 11 Aug 2023, 16:44 That's good news, I expect thats the cause of your horrible engine sound. I had a Corvair years ago that had a very small crack in the flywheel and it made the engine sound like it was coming apart, similar to yours. How long did it take you to get the oil pan off?
It wasn't too bad to get the oil pan removed. Say about 1-2 hours
1. Remove oil dip stick
2. Remove cover under the engine
3. Drain the engine of oil
4. Remove the oil filter
5. Remove the oil cooler from the block
5. Remove the screw holding the fuel line
6. Then start to remove the oil pan but keep 4 bolts.
7. Tap the oil pan lightly using a soft faced mallet.
8. Remove the 4 remaining bolts holding the oil pan in place.
9. Carefully wiggle the oil pan out.
No between the oil pan and the block. On a P80 there are o-rings for the oil feed to the head.
vtl
Post by vtl »
scot850 wrote: 11 Aug 2023, 19:13 No between the oil pan and the block. On a P80 there are o-rings for the oil feed to the head.
Yes, of course, it is the same engine, basically.
greffel
Post by greffel »
I'm hoping the flywheel was the source of the bad sound.
Any other maintenance that we should do while the pan is of ?
The seal we are talking about is this one ?
