Help diagnosing bad engine sound *solved* Topic is solved
Has thanked: 2205 times
Been thanked: 1852 times
I believe there are 2 but happy to corrected, and yes that looks like one of them.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
There are 2 such seals. But replace them all, they come in one kit. Look for part numbers here: https://www.fcpeuro.com/products/volvo- ... -reinz-kit Can buy Volvo or Reinz, doesn't matter much, I've used both.
FYI, Permatex anaerobic sealant seals better than Volvo.
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 8 times
Post by greffel »
....and the results :)
Problem fixed, and it was the lose bolts that holds the torque converter.
So happy now because last week I had my mind set on a replacement engine.
Now I might have the cleanest oil pan in this forum also :)
Big thanks for your support
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Nicely done! What did you use to clean it? I think this next on my list of things to do on my car, I was going to drop it in the hot caustic tank but would prefer a gentler method of cleaning.
2003 XC 70 (sold)
RobsS40
Year and Model: 2006 S40 T5 AWD
Has thanked: 2 times
Been thanked: 7 times
Post by RobsS40 »
New here, new to Volvo. I changed a rod bearing a few weeks ago. Pan was horrible. Tried different solvents and cleaners. On a lark I used powdered laundry detergent and my before and after look like greffel's, maybe more extreme on both ends. I didn't take pics, but pan was shiny like new.
Great news on the engine rattle resolution and the info on cleaning the oil pan.
Geraldt
Year and Model: S60 2.5t AWD 2003
Post by Geraldt »
Blacklab467 wrote: 12 Aug 2023, 18:39 Nicely done! What did you use to clean it? I think this next on my list of things to do on my car, I was going to drop it in the hot caustic tank but would prefer a gentler method of cleaning.
We filled up the oil pan with this exact detergent
https://www.biltema.se/en-se/car---mc/c ... 2000041533
Not sure what product you have available in Canada
We have many degreaser type products, but not all are good at removing the hard backed on oil. Thanks for the info though.
seggs
Year and Model: '09 S60, 04 XC70
Been thanked: 4 times
Post by seggs »
I have a similar sound on my 2009 S60. Where exactly are the “bolts between the flywheel and torque converter” located? A picture would be enormous help.
:mrgreen: Seggs
2009 S60 2.5T FWD 155k
2008 S60 2.5T FWD 150k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
There is an access port if I recall on the firewall side of the engine near the bellhousing. You will have to rotate the engine/flywheel until you can see each bolt. If you can remove and re-Loctite then with blue Loctite each bolt bolting the flex-plate to the flywheel that is the best way to tighten/check for loose bolts.
There should be 6 bolts as per this picture:
https://www.ebay.ca/itm/166027956193
You will have to rotate the engine to get to each one.
