Hello,
These are NLA new and I was wondering if anybody has a set of 4 laying around.
They should fit the old square style cross bars.
Thanks, Dirk
WTB, Volvo S70 Thule cross bar mtg feet
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 1611 times
- Been thanked: 4075 times
Trying to remember if I have two sets of these. I think I do as I needed them when I owned six houses. Now I have one
- 850 LPT
Time to go back to the shed?
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 2211 times
Dirk, can you post the bars you are looking for and the parts you need if you can. There is a car in a junkyard, but I think the roof rack was for a non-roof rail car. I need to check my garage as I think I may have only one rail for a roof rail car. The bar is 'tired' but the mounts may be ok. I will try to find it over the weekend. If I do I will post a picture to see if it is what you are looking for.
Should add, are they NLA from Volvo or Thule or both? If NLA from Volvo, a rack supplier may be able to find Thule ones.
- 850 LPT
Hi Neil, thanks for looking into this. I am actually looking for the cross bars and mounting feet for a non roof rail car, since mine is an S70. Unfortunately I cannot find any part numbers. Also, I have a set of rectangular cross bars that should be long enough. So what I really only need is the mounting feet.scot850 wrote: 11 Aug 2023, 23:01 Dirk, can you post the bars you are looking for and the parts you need if you can. There is a car in a junkyard, but I think the roof rack was for a non-roof rail car. I need to check my garage as I think I may have only one rail for a roof rail car. The bar is 'tired' but the mounts may be ok. I will try to find it over the weekend. If I do I will post a picture to see if it is what you are looking for.
13' Honda Odyssey
13' Honda Odyssey
So you are looking for a set with the little latch pin that locks into the door frame at the top.
OK. Then those were that type. Someone had modified them to mount a flat wooden sheet by drilling 2 holes either end of each bar.
If you are ok with that then if I get a chance I will go see what they charge for them. I know PnP charge around $35 CDN for a pair if I recall, but this is in another yard. I think that charge about the same.
- 850 LPT
Yes, I guess that's the correct type. I have never seen how they actually install. Since there are M6 holes in the top of the doorframe I was assuming that they would screw in somehow. But I can see how that would work with a pin that is perhaps pulled up.
I am going to look at a pair that I found locally this evening. If that falls through somehow I will come back to you. I will let you know either way.
Thanks again,
Dirk
Thanks again,
Dirk
13' Honda Odyssey
13' Honda Odyssey
- 850 LPT
13' Honda Odyssey
13' Honda Odyssey
Don't think those are Volvo/Thule, certainly not a version I have seen here. The feet look wider. Either way let me know how you get on. I may head to the junkyard for something else on Wednesday as it is the only cooler day this week (27C!).
Good luck locally with that set!
- 850 LPT
Hi Neil, the set I looked at yesterday was for a P2 unfortunately, and they are very different. So if you could take a look at that junkyard, I would appreciate it. If the feet are for the Thule rectangular bar, then I only need the feet. I have a set of those bars and it would be cheaper shipping just the feet.scot850 wrote: 14 Aug 2023, 13:42 Don't think those are Volvo/Thule, certainly not a version I have seen here. The feet look wider. Either way let me know how you get on. I may head to the junkyard for something else on Wednesday as it is the only cooler day this week (27C!).
Thanks, Dirk
13' Honda Odyssey
13' Honda Odyssey
