Hi everybody!
My front lens on the right is showing age and has gone all blurry. I can try to polish it and hope for the best, however, I was wondering if the v70 (2001) lenses would fit (they are glass)
XC70 - Front headlights swap
Stonedraider88
- Year and Model: 2005 XC70
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The 2001 may not fit. You can search the part number and map it for fitment; try this https://www.ipdusa.com/Catalog/Index?se ... 0headlightStonedraider88 wrote: 15 Aug 2023, 04:10 Hi everybody!
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
The glass headlights pre '05 will not fit. I've had good results making plastic headlights look new by wet sanding with 800-1000-1500-2000 grit sandpaper in that order followed by power polishing with a cut and polish like Meguiars or 3M.
2003 XC 70 (sold)
Stonedraider88
Noted, thanks! I will try to polish them as you suggest, do I need to put any kind of film or clear coat over the lens after? I am wondering how long will the polish last.Blacklab467 wrote: 15 Aug 2023, 07:45 The glass headlights pre '05 will not fit. I've had good results making plastic headlights look new by wet sanding with 800-1000-1500-2000 grit sandpaper in that order followed by power polishing with a cut and polish like Meguiars or 3M.
Stonedraider88
Stonedraider88
Got you, thanks!xHeart wrote: 15 Aug 2023, 07:36The 2001 may not fit. You can search the part number and map it for fitment; try this https://www.ipdusa.com/Catalog/Index?se ... 0headlightStonedraider88 wrote: 15 Aug 2023, 04:10 Hi everybody!
I also have a faulty body position sensor, so the headlights droop to the lowest position. So at the moment the motors in the headlight assembly are unplugged and are manually set up so they dont move. However this throws up the "headlight failure" message. I know where the sensor is located and it seems like an easy replacement, however I read up somewhere here that it needs programming, any pointers on that? Also I am struggling to find the actual part number, there are two types and I am not sure which one is for the XC70 P2.
Is this it? Part number - 31300198
vtl
- Has thanked: 130 times
- Been thanked: 686 times
UV-resistant coat is pretty much must or it won't survive even a few weeks. Some kits come with such coat, like Sylvania headliht restoration kit.Stonedraider88 wrote: 15 Aug 2023, 11:37 Noted, thanks! I will try to polish them as you suggest, do I need to put any kind of film or clear coat over the lens after? I am wondering how long will the polish last.
Still, it's a temporary measure. I had to do it roughly once a year. Wrapped in polyurethane film a few years back, it's not perfect and still yellows, but at least it ages better than just polished lens.
- 3458 Views
Last post by ShadowDancer
- 884 Views
Last post by chrism
- 16 Replies
- 3843 Views
Last post by E Showell
- 220 Views
Last post by FarmallM51
- 527 Views
Last post by VolvoDJ
