850 Bumper and trim restoration
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Do you plan on applying the Cerakote yourself ? If so let us know how that goes.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
foggydogg wrote: 16 Aug 2023, 06:47 Do you plan on applying the Cerakote yourself ? If so let us know how that goes.
I applied the Cerakote a day or two after I redyed them. Came out great. You have to be careful with that stuff. Don't keep going back over it; that will cause streaks. Just a smooth even coat and go over it as little as possible.
1999 V70 GLT
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Sveedy, are the two bottles in your pic the same product, but one is turned 180 for the label?
Sveedy
Post by Sveedy »
Two different colors from a different manufactures that are connected in a round about way, from what I can tell. The gray has a note on the bottle - " From the founder of Solution Finnish ". Same bottle and directions. So maybe a split-up of some sort between founders, and one got to keep the name Solution Finnish ?
" You better not make Black. "
" Fine. I'll make gray. And you can't have ANY of it. "
" Fine. I've got the name. "
Just guessing....
1999 V70 GLT
Sveedy
Post by Sveedy »
Re: the Cerakote; I think Solution Finnish also makes a sealer. I used the Cerakote because I had already bought it, figuring on just using that. I'm sure it would have been great, but I was worried that if I didn't do something about the stains first, that they would become permanent after sealing.
1999 V70 GLT
TIMT5
Year and Model: 1995 850 T5
Post by TIMT5 »
Hi Sveedy
Could you tell me which Cerakote product you used to protect the trims after giving them the color refresh ?
Thanks
Regards
Tim
Sveedy
Post by Sveedy »
Here you go Tim -
This is how it has stood up to the Arizona sun over 2 1/2 years. Not bad at all imho.
1999 V70 GLT
