I guess I’m going to call him “Leo”
- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
I just got my perforated leather steering wheel cover in from the UK. Very nice quality. I haven’t stitched up a cover since the late 70’s.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- Has thanked: 2203 times
That looks like a really nice product! Nice stitching job too.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Did you notice that little button on the brake pedal is lit ? I never did try to figure out what Leo was up to there.DonnVa wrote: 14 Aug 2023, 18:03 I just got my perforated leather steering wheel cover in from the UK. Very nice quality. I haven’t stitched up a cover since the late 70’s.![]()
It isn't a form of cruise control?
- DonnVa
Yes, it actually operates the brake lights. It’s more reliable than the pressure switch attached to the brake line manifold mounted to the firewall. There is also a small LED bulb hanging behind (under) the dash that lights with the brake lights. I assume that was mounted somewhere at some point to give him feedback that the brake light circuit is working. Lots of Easter eggs in the car..foggydogg wrote: 14 Aug 2023, 21:44Did you notice that little button on the brake pedal is lit ? I never did try to figure out what Leo was up to there.DonnVa wrote: 14 Aug 2023, 18:03 I just got my perforated leather steering wheel cover in from the UK. Very nice quality. I haven’t stitched up a cover since the late 70’s.![]()
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
O'Leo! You have new and expensive leash.DonnVa wrote: 14 Aug 2023, 18:03 I just got my perforated leather steering wheel cover in from the UK. Very nice quality. I haven’t stitched up a cover since the late 70’s. 😂
- DonnVa
Na, I’m freeing up his inner Amazon. Letting him be all he can be..
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- DonnVa
I was supposed to be out of town on business all week, but that changed, so I’m getting a head start on the driveline repairs. I took the drive shaft out and replaced the center bearing and associated stuff. The U joints are good, so that is set to the side. I took the transmission out a little while ago and discovered the sources of some of the noises I’ve been hearing. A banging while releasing the clutch to take off in 1st = broken transmission mount. A low grumble when I let off the gas and coast in 4th= toasty transmission input shaft bearing. I placed a quick order with VP I’m hoping to get on Saturday. I’ve got everything I need except internal transmission parts. I’m going to get the clutch in tonight or tomorrow and have everything done waiting on the trans fix. I’ve got to make a dummy laygear counter shaft once I figure out the dimensions.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
Watch out for wear on the brass rings in the trans. They can make the change baulky/crunchy.
- DonnVa
I bought a handful of parts not knowing what I may need. Right now, the trans shifts smooth and I can hop gears downshifting. All the shifting functions and synchronizers seem to be real good. I don’t plan on disassembling the main shaft any further than I have to. However, I purchased 1 synchronizer ring and 4 dog springs along with the input and output bearings, counter shaft for the lay gears, 2 set screws and the roll collar. I have a full gasket kit already. I’ll be able to put it back into service better than it came out. Hopefully not “famous last words”.scot850 wrote: 16 Aug 2023, 19:22 Watch out for wear on the brass rings in the trans. They can make the change baulky/crunchy.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- 1349 Views
Last post by volvowagongirl
- 1833 Views
Last post by June
- 8242 Views
Last post by URDRWHO
- 2259 Views
Last post by tehniemer
- 30 Replies
- 3178 Views
Last post by Clemens
