Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
02V70 wrote: 16 Aug 2023, 22:41 I drove two hours for a dentist appointment, and 3/4 hours back through some beautiful mountain roads including a "shortcut" through an uneven dirt/rock logging road. I did the zip tie fix for the a/c, and it worked the whole way in 100-degree weather.
Beautiful picture, where is that in CA? And what is the zip tie fix for the A/C?
2003 XC 70 (sold)
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Uneventful oil change on the 08 S60 2.5T at 159,000 miles on a 5000 mile interval this time. I’ve put 20,000 on the car in last year and a half, most OCIs at 3000 miles as I didn’t like some of the sludge/carbon buildup. Much cleaner under the cap now.
Havoline High Mileage Synthetic Blend this time, typically run full synthetic but the 6qt box is convenient (and cheap).
08 C70 gets an oil change and a bit of diagnostics on lingering suspension noises this weekend. I suspect swaybar bushings need replaced as most other components are new.
08 C702.5T (sold)
The non-Swedes:
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Blacklab467 wrote: 17 Aug 2023, 20:35 Beautiful picture, where is that in CA? And what is the zip tie fix for the A/C?
I was just south of trinity lake when I took the photo. (Large lake in far northern California) The ziptie fix is described in this thread . Basically, the a/c clutch doesn't engage most of the time, so you can shim it closer to the electromagnet.
2002 v70 X/C 288k miles
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Similar to the bread wrapper clip fix I've read about?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Did the zip tie rig on the AC compressor today.
Also replaced passenger side axle.
Rotated tires.
Cleaned rear brake pad and bent plate back because it was running and making noise for longer than I would like to admit. Pads and rotors need replacing- guessing as a result of a seized calliper last year that got replaced but I never replaced the disc/pad.
Old thread saved my arse, I stripped the tensioner T60 so I used the 14mm bolt head instead to remove and replace the belt. Crisis averted.
04s60 2.4
04xc70 2.5t
02V70
Post by 02V70 »
BlackBart wrote: 18 Aug 2023, 11:50 Similar to the bread wrapper clip fix I've read about?
Yeah, it’s pretty much the same thing, except the dip ties don’t fall off.
TisMe
Year and Model: 2001 & 2004 XC70
Has thanked: 42 times
Been thanked: 17 times
Post by TisMe »
Drove my dad’s XC from WV to DC. Discovered an undeniable steering wheel notch/shimmy at 70-80, so I figured I’d pop the car up in my late uncle’s driveway while the parents go about their business.
At first I set eyes on the the somewhat aged control arms. Then I became suspicious of the tie rods. Eventually, I put a wrench to the tie rod and discovered a disgustingly loose nut -_-
I know this car was recently aligned at a local shop… I’m a passive guy, so I’m currently contemplating whether I mention it to their receptionist.
All in all, a great day for a hackjob mechanic! 110 heat index be damned, at least the folks won’t flop a tire anytime soon.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Made a start on cleaning the underside of the V70 in preperation for its first application of Lanoguard. For an 18 year old car it really isn't very dirty, there's none of the usual mud build up and the clean up is just to get rid of road splashes that have dirtied the underside over the years
This is before any cleaning pictures
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Antikythera mechanism , opens a window on the universe.
cheaper version of the Greek original.... I think.
BlackBart
Post by BlackBart »
Whoa!
