2004 XC70 no start - faulty fuel pump and/or electrical connections? Topic is solved
Been thanked: 4068 times
I’m going to push you away from the “ junk in tank diagnosis”. You don’t get crap in fuel anymore unless someone hates you and puts it in your tank directly, likewise for plugged fuel filters.
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
abscate wrote: 16 Aug 2023, 02:13 I’m going to push you away from the “ junk in tank diagnosis”. You don’t get crap in fuel anymore unless someone hates you and puts it in your tank directly, likewise for plugged fuel filters.
"Old junk" hanging around in a 19-year-old car and finally causing problems? Does the inlet really have an impeller that can fail? Is it powered? I have everything needed to disassemble/reassemble the entire fuel pump unit (but not replacement parts). Replacement won't answer the question without a diagnosis.
I could drive it two floors down into the parking lot at work hoping it will fail.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Danalberto231
Year and Model: 1989
Post by Danalberto231 »
I also think I read that the PEM was introduced to the XC70 sometime during the 2004 model year. Maybe my 2004 XC70 is pre-PEM? Would a VIN lookup provide that info? How about a scan tool?
Hubspot partner agency
Mehendi designs
enotslim
Post by enotslim »
I don't remember finding any information via the VIN or using a scan tool about presence or absence of the PEM in my 2004 XC70. I never found one by looking in all the known locations as described earlier in this thread. Vida/DiCE seems like it might provide info about the presence/absence of a PEM. I have Vida but not DiCE so I can't try this. Does someone know for certain? As in have you detected lack (especially) and/or presence of a PEM this way?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Been thanked: 504 times
Post by cn90 »
Please list locations you have looked for PEM...
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
enotslim wrote: 19 Aug 2023, 08:00 I don't remember finding any information via the VIN or using a scan tool about presence or absence of the PEM in my 2004 XC70. I never found one by looking in all the known locations as described earlier in this thread. Vida/DiCE seems like it might provide info about the presence/absence of a PEM. I have Vida but not DiCE so I can't try this. Does someone know for certain? As in have you detected lack (especially) and/or presence of a PEM this way?
2003 and up it should have a pem. jack up and use jackstand,
passenger side of tank, looking up it sits on top of tank peeping out.
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Post by goldxc70 »
Danalberto231 wrote: 17 Aug 2023, 06:53 I also think I read that the PEM was introduced to the XC70 sometime during the 2004 model year. Maybe my 2004 XC70 is pre-PEM? Would a VIN lookup provide that info? How about a scan tool?
Mehendi designs
I believe this is correct. Some 2004 models do not have PEM while some later models do. I double checked this with my indy Volvo shop (long time Volvo tech).
goldxc70
Post by goldxc70 »
enotslim wrote: 15 Aug 2023, 20:51 ...Can the fuel pickup/impeller/(not a siphon) be serviced? Blocked by "stones" that presumably precipitate from contaminants in the tank?
In my case, thhe pump itself appeared to be fine but the fuel pickup/impeller appeared to have failed. I can't say of this was caused by wear or contamination in the fuel but it was definitely not free to spin as the new one was.
jonesg
Post by jonesg »
goldxc70 wrote: 04 Sep 2023, 09:20
i ran my old volvo on fumes too often and burned the pump up.
Has thanked: 311 times
Been thanked: 817 times
My 07 XC70 I was troubleshooting the PEM and I didn’t the PEM anywhere in VIDA.
