01 V70 tailgate does not lock with remote or door switch
- mp5802
- Year and Model: 2001 V70 T5
I've had my 01 V70 T5 for 9 years. Recently, I tried to lock the car with the remote and all 4 doors lock properly, but not the tailgate. One can just open the tailgate, and then sometimes the security alarm does sound. There's no audible click either at the tailgate when trying to lock the car. I've been searching a bit, and a few recommendations say that the harness wires may be broken where it passes through the left hinge area. The fuse is good. Other ideas?
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Broken wires in the left hinge area is a known problem. Do you have any other problems with the tailgate? The wires going through the left hinge area will affect the rear lock, license plate lights, rear wiper, upper brake light, tailgate open (ground wire through switch in tailgate latche), rear defroster; do you have any problems with any of these other items mentioned? If so, likely broken wires in the hinge area.mp5802 wrote: 22 Aug 2023, 17:29 I've had my 01 V70 T5 for 9 years. Recently, I tried to lock the car with the remote and all 4 doors lock properly, but not the tailgate. One can just open the tailgate, and then sometimes the security alarm does sound. There's no audible click either at the tailgate when trying to lock the car. I've been searching a bit, and a few recommendations say that the harness wires may be broken where it passes through the left hinge area. The fuse is good. Other ideas?
There's also a relay associated with the rear latch, see attachment, RMI19
- mp5802
Yes, I found 5 broken wires in that bundle going through the left hinge. I repaired them, and the tailgate now locks again, although, now, the darn handle won't always open the tailgate after unlocking it unless you fiddle with it (sticking somehow). Well, being able to lock the vehicle is most important. Thanks for your help;
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Theres lots of videos on that sticky rear hatch handle on youtube.mp5802 wrote: 23 Aug 2023, 15:54 Yes, I found 5 broken wires in that bundle going through the left hinge. I repaired them, and the tailgate now locks again, although, now, the darn handle won't always open the tailgate after unlocking it unless you fiddle with it (sticking somehow). Well, being able to lock the vehicle is most important. Thanks for your help;
- Been thanked: 4064 times
Don’t forget they can short and blow fuse 6, which wipes out your 2/76 lock controller , which means your car will then no crank no start….Broken wires in the left hinge area is a known problem. Do you have any other problems with the tailgate? The wires going through the left hinge area will affect the rear lock, license plate lights, rear wiper, upper brake light, tailgate open (ground wire through switch in tailgate latche), rear defroster; do you have any problems with any of these other items mentioned? If so, likely broken wires in the hinge area.
- Been thanked: 504 times
Just went through this with my 2006 S60.
New wiring harness ~ $50 or so.
PN is different for V70 vs S60.
I fix a lot of stuff, but this is a part I would not bother to fix using butt connectors, simply bc they keep failing at that age.
Just get a new harness.
I posted the trick for S60 in this forum.
- 1195 Views
Last post by nsjames
- 1596 Views
Last post by Clemens
- 1439 Views
Last post by joevar
- 773 Views
Last post by MadeInJapan
- 1095 Views
Last post by bmdubya1198
