Definitely not a drip into sump on mine. It pumped out 2-3 quarts in way less than a minute, barely enough time to go through the gears on jackstands. This was on a 02 S60 2.4T FWD and 05 S40 2.4i FWD, maybe we are talking different transmissions.vtl wrote: ↑26 Aug 2023, 07:23It's no different that drain and fill. Valve body diverts only a part of ATF flow to the cooler. Fresh ATF from return line drips into sump where it mixes with the old one. No difference. Perhaps, drain&fill is even more efficient, since it replaces 1/3 to 1/2 of the fluid in one pass.
I kinda wish I would have pulled the drain plug to see how much was in the trans sump after pumping 3 qts out via the cooler, would be interested to know.
