Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
P80GLT wrote: 26 Aug 2023, 12:24 Gave the 850 a quick wash early this morning before heading out to Lesmahagow and the Auchlochan Car Show
I'm very jealous ! :) It seems like you get to participate in a car show every week or two. And on a nice lawn as well.
Nothing like that around here.
Your baby looks beautiful !
1999 V70 GLT
Has thanked: 2210 times
Been thanked: 1852 times
No it does not close entirely or your car would be totally starved of air it needs to run. All of my throttle bodies I have spare look like yours and sit slightly open. The position is adjusted for temperature based on external air temp.
Neil
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Sveedy wrote: 26 Aug 2023, 13:36 I'm very jealous ! :) It seems like you get to participate in a car show every week or two. And on a nice lawn as well.
Thank you Sveedy, I guess I lucked out when I bought it, I doubt there's a more original 850 left in the UK now in the same condition.
I've been to very few shows this year as I fractured my back in May which put me out the game for a while, just trying to make up for lost time now before the shows finish.
Yes that lawn was amazing, but not as good as it was last year when we were there, I think the wet weather from the last couple of weeks hasn't helped
This was last year
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
306V70
Year and Model: v70 2001
Post by 306V70 »
Changed water pump (was leaking like a basket) and the timing belt on my v70 t5 mod-year 2001. 300000Km. Went ok.
(Radiator still leaking as well...)
I pulled the Temp sensor connector plug during engine operation. Was not sure if it would work at all. Fan kicked in and did never stop again, even with reconnected temp sensor... Regardless of Ignition Key position. Interesting was, that the temp gage reads nothing even with engine running and hot. I could fix the problem by disconnecting the Battery for five minutes. Everything back to normal. Maybe it it helps somone out there. Seems that either the ECU or the Fan controller has a fail safe fan operation programmed..... Better kill the Battery than an Engine in a real fault situation. (sorry my english)
Has thanked: 1611 times
Been thanked: 4075 times
Bruno, on Silver Bullet
That start up looks good. It’s still running up to 5000 rpm?
You actually have an idle air valve on a Denso NA ETM. Maybe try unplugging that to see if that’s bleeding air
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
brunocerous wrote: 26 Aug 2023, 13:02 I’m back in Queens visiting my parents and hoping to work on the Silver Bullet’s ETM. I’ve got the Interstate battery out of Blue Steel and on a charger to listen again for the click and whirr of it initializing after having it repaired by Xemodex.
Thanks, FireFox31, for the ETM startup post. The Geronimo thread is amazing. viewtopic.php?t=98286
abscate wrote: 22 Aug 2023, 02:48 Might have some Queens time on Thursday this week. Have to pick up Caitlin inFort Greene after work Thursday pm, so could swing out earlier to beat traffic. I have a spare known to be good ETM , I think I can find it…
Thank you for the offer! It was a busy week at work, and I didn’t have a chance to even think about getting out here.
Update: Here’s video of the ETM while turning the key to position II. Is the throttle plate supposed to close entirely?
That looks like normal operation.
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
MAJOR stuff!
rotate balance alignment (was way off)
microfilter cabin filter replace (was way dirty)
spark plug wires
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
brunocerous
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I crossed my fingers and gingerly turned the key, and it ran slowly up to about 2,500 RPM, the settled down to about 1,500 RPM, fluctuating a bit back up to 2,500 and down again a few times. I ordered a new MAF sensor in the meantime.
I did get a new code, P0118, and noticed that my temperature gauge didn’t move even though I ran the engine for a few minutes. In the winter, I’ve noticed that it took a longer than my other P80s time to get the heat going full blast. I’ll order an OE sensor, too.
abscate wrote: 26 Aug 2023, 15:11 Bruno, on Silver Bullet
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
While not perfect, it is nearer normal, especially if your temp sensor is not registering correctly. Mine will idle around 14-1500 rpm on a cool day for a few minutes and then drop to normal.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Not to my either of my Volvo's, but to my garage/parts-stash..... sorting, and condensing parts to hopefully a single area, and stored in a new cabinet. I found that I had very carefully stored a known bad O2 sensor, even to the point of putting the plastic shield on it from the replacement. Why oh why would I do that???
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
