I've not had a FWD P80 in a long time (>5 years) and I recall it had a problem with something seized or broken at the rear which prevented the local dealer aligning one side at the rear. Unfortunately I was not there to see what got changed. I do (surprisingly!) remember a conversation about a corroded or cracked aluminum block. I seem to recall there is an aluminum block with a couple of bolts mounted near the delta link. I also recall aluminum block/steel bolts mentioned. I know how that does or doesn't work on my AWD Volvo's!
Are those what need to get de-rusted or replaced? If so are there any options other than OE?
96 850 Rear wheels - Lack of adjustment Topic is solved
- Has thanked: 2200 times
Probably the link block at the end of the torsion bar.
This guy, still available in Meyle or PPS…not awful
https://www.fcpeuro.com/products/volvo- ... 96-3516497
It is also sold by our friend URO....................!
I need to find it north of the border but now I know there are alternates (OE NLA it appears). Thanks for the heads up. I do recall the Volvo mechanics swearing a lot removing the one on my 00 V70 NA that had actually snapped!
Found the item at GermanParts.ca. They have the Meyle parts (is there a LH and RH or are they the same?), URO and Sidem?
$42 is about the same as $30 US and no shipping with local pickup. This company is beginning to impress.
Right and left are different, correct.
8631284 right NLA Volvo
9181013 left still available from Volvo for $80
- 1183 Views
Last post by juggernaught_666
- 2369 Views
Last post by carboncow
- 509 Views
Last post by rspi
- 1195 Views
Last post by MikeX
- 1311 Views
Last post by misha
