I've started the process to remove the fuel tank in an effort solve a hidden leak issue. Car is raised, Exhaust is out, Trying to drop the drive train in the rear. I removed the Hex Bolts from the rear angle gear and tried to separate the drive train. Unsuccessful.
Do I have to remove the front hex bolts at front angle gear too in order to get it out of the rear? How do I get the drive train out of the rear angle gear. Its loose and just does not have enough clearance. If possible Id like to leave the front connected and just drop the rear so I can sneak the tank out (if possible).
2004 XC70 AWD - Gas Tank Removal - Rear drive train Removal?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I would avoid doing that.
have you removed the pump access cover (under the bench seat), almost all leaks are from the pump top mount...or fuel filler tube.
almost all leaks can be fixed without taking the rear drive out.
cuhfs
This is a leak not under bench seat or near fuel filler tube. I'm "all in" committed to pulling the tank. Just need to know how to remove the drive-line.in the rear angle gear. I have removed the hex bolts from the hub but the driveline wont clear it (the hub) to drop out the drive line.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
To remove the driveshaft from the haldex it first needs to be removed from the front differential. After getting the front removed just let it sit to the side of the differential.
There are two threaded holes in the rear of the haldex. Some members had luck popping the rear CV joint using an air chisel thru those holes.
cuhfs
Thanks I will look to do that.. I hear you saying there is no way to release the drive train from the rear if the front is connected.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
There's not enough room to remove the driveshaft from the rear flange just at the back, you must remove the front from the angle gear and the bearing support in the middle. This is easiest if you remove the muffler hanger and exhaust hanger and lower the exhaust and move it towards the driver's side. Be cautious when taking the shaft out when you have all the Allen screws out, the CV's will try to come apart and it gets messy!
2003 XC 70 (sold)
- 9 Replies
- 1049 Views
Last post by XC70Rider
- 700 Views
Last post by wanderdüne
- 1390 Views
Last post by Johnnyangel
- 16 Replies
- 870 Views
Last post by Brickbox8398
- 1448 Views
Last post by joevar
