Been there, done that... I try to throw away bad parts as quickly as possible to avoid doing this454cid wrote: 27 Aug 2023, 17:10 Not to my either of my Volvo's, but to my garage/parts-stash..... sorting, and condensing parts to hopefully a single area, and stored in a new cabinet. I found that I had very carefully stored a known bad O2 sensor, even to the point of putting the plastic shield on it from the replacement. Why oh why would I do that???
- Has thanked: 317 times
- Been thanked: 531 times
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
I also wonder why I do such things. If you figure it out, please let me know!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 2215 times
- Been thanked: 1853 times
Um, because you are a guy!?? Doesn't everyone one do that? I will do that very occasionally with a part on a car I know is a chassis change over in case I have to buy again and keep it as a reminder.
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
On Friday I went to Tulsa. Before going over to help unload stuff from a uhaul and trailer into my sister's new house, I stopped at LKQ to scope out the 2nd c70 they got recently for another 4x100W amplifier. I now have two 4x100W amps. I already have one 6.5" Skar (2ohm, 200Wrms, dvc) subwoofer and I plan to get a 2nd one. I think I am going to remove the 3" Skar tweeters and put a factory pair in. These parts should come in handy later on in the '~P1155' department. There are some things you learn along the way when you are young and regret doing those things when you are older. Well, my cheaping out has taught me a lot of lessons.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 1613 times
- Been thanked: 4077 times
2 hours on Elizabeth the T5
Wiped and oiled cylinders
Installed head gasket
Installed thermostathousing
Installed cylinder head
Torqued cylinder head bolts
Installed 2 m6 water pipe bolts.
She will ride again sokn
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 116 times
In my lazy quest to fix the coldstart/high LTFT issue, replaced the fuel pressure regulator and some vacuum hoses today after work
Good bit of fun that job, I wish I had the version with the FPR under the fuel rail
Drove it around for 10min, it seems a bit happier and the LTFT is going down. The real test will be the coldstart tomorrow !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
That's an "I just want the pads" situation!
Got head on Elizabeth , did quick cam cover and belt but she runs funny. Air is sucked into the tailpipe and exhaust comes out of air cleaner
I’m baffled
( beautiful aluminum art)
I’m baffled
Are the cams rotated 180 degrees?abscate wrote: 28 Aug 2023, 18:33 Got head on Elizabeth , did quick cam cover and belt but she runs funny. Air is sucked into the tailpipe and exhaust comes out of air cleaner
I’m baffled
