I guess I’m going to call him “Leo”
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
Well it’s together and shifts. Whew… Putting it together is a very tedious job. I’m going to take a take a dinner break and see how motivated I am to put it in tonight.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Leo was known to do mix-and-mash, parts of that gearbox may have come from one of his earlier cars. At least one of his 1800s was a daily driver and came with him when he moved from NY, and I know he put way lots of miles on it.
He also had, ahem, several Amazons...
Been thanked: 4068 times
Donn...thanks for keeping the resurrection alive, it’s good for the soul. I know foggy appreciates it , too.
DonnVa
Post by DonnVa »
I put in the transmission and driveshaft last night and finished everything up this morning. I took it out for a test drive and man the difference is like night and day. No more hopping and banging trying to take off in 1st. 😂 It’s smooth as butter. New rear main seal, clutch, trans refresh, driveshaft center support bearing.. Done. I also installed a 10” electric fan for the radiator and hooked it up to the toggle switch that was still live for the dead electric fuel pump I removed. No more biting my nails at a stop light w/ the temp about to peg. Just flip a switch. 😬
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
DonnVa
Post by DonnVa »
Well, I bit the bullet and bought a new gas tank last Friday. I installed it tonight. While I was working on the car last week running it in the garage, it ran out of gas at a half a tank. I took a look in the old tank after I got it off and it indeed did not have a pickup tube running from the outlet mid way up to the bottom of the tank….
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
DonnVa wrote: 29 Aug 2023, 18:58 Well, I bit the bullet and bought a new gas tank last Friday. I installed it tonight. While I was working on the car last week running it in the garage, it ran out of gas at a half a tank. I took a look in the old tank after I got it off and it indeed did not have a pickup tube running from the outlet mid way up to the bottom of the tank….
Has thanked: 2202 times
Been thanked: 1852 times
Would putting a tiger in your tank not block the fuel pick-up and likely only allow about half a tank??
Even 40 years ago the fuel tanks would get porous around the filler neck at the tanks, and also the seam.
DonnVa
Post by DonnVa »
I’m been doing a lot of little things the last week or so. When I had the car up on jack stands for a few weeks working on the driveline the brake master cylinder leaked out. It leaked through the boot behind the firewall. Foggy sent me home with a brand new one when I bought the car. I bought a new cap and used the old one to create a power bleeder cap for it. It worked great. I actually completely flushed out all the brake lines with new fluid. I mentioned that my speedo was about 20 mph fast. There was nothing out of the norm in the trans when I serviced it. Standard speedo worm gear and standard yellow speedo gear. Foggy also sent me home with a spare instrument panel. I bought another speedo cable with one of my VP orders, hooked it up and ran it through the engine compartment and up to the hood. I secured the other speedo on the hood by the windshield to see what that one read. It’s accurate, so when I get around to replacing the cracked dash I’m going to swap the speedometer from the old unit to the one that’s in there now. The instrument panel innards are modular. I also got donor horn ring to cut up. I didn’t like the top portion and the way it interferes with the gauges, so my plan was to cut off the top portion of the ring. However, when I did it, it was late and I was tired. I cut off the bottom portion by mistake. I didn’t notice until I got into the car and put it up against the steering wheel. That’s when the cussing started… 😂 I had no other choice but cut the top off and I’m liking it. Last thing, Froggy wanted to see what the old clutch looked like. I snapped a pic before I took it to the dump.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
foggydogg
Post by foggydogg »
Clutch had some miles left in it; of course I drove it like the vintage survivor it is. Leo, on the other hand...
His daily driver when I met him was a Honda Civic Si, and he mentioned - more than once - that he loved shifting at redline, which I think on those cars is north of 8k, so the hotspots on the plate surface are no surprise.
DonnVa
Post by DonnVa »
New polished stainless steel bumpers installed. I gave up on trying to get the rear Volvo trunk emblem re-chromed. Too many variables on getting pot metal refinished.. long wait times, unpredictable results, etc. I sanded it, used self etching primer, then a filling primer, sanded and painted it with a cast aluminum paint. Then I baked it. I did save the only chrome left on it. That will have to do for now.
Edit- This funky paint job that Leo did is growing on me. It’s going to be hard to redo it to all black or black with a white top. Another thing I finding is the base color under the door cards is that Volvo greenish blue.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
