wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
After the cam cover is in place. You won't likely have a good seal otherwise.
2023 Lexus RZ450e -66k
wizechatmgr
Replaced the rear shock mounts on the '98 V70 today... Was doing the california lowrider/hydraulics thing when you stepped on the brakes. This would be why...
wizechatmgr
abscate wrote: 29 Aug 2023, 17:02 …and Elizabeth progresses….one really good hour+ today
Dipped lifters into a cap of oil then dropped into place.
Make sure plug holes are paper plugged
Dab and prep both cover sides to Barbie pink with Permatex and foam roller
Install cams , exhaust notch down, intake up
Lube cam thrust bearing with grease
Confirm crank mark
Install spark plug orings
Install cam cover
Bring down cam cover with cylinder 2,4 bolts …4 each cylinder
Install rest of cylinder bolts
Do rear side
Do front side
Confirm cams rotate with reasonable force
That machine shop really gave you some great head. =)
Has thanked: 1613 times
Been thanked: 4078 times
ZionXIX wrote: 29 Aug 2023, 22:07 Abscate, when installing the cams and cam cover, do you try and seat the cam seals during assembly or leave them loose and tap them in after the cover is bolted down?
I cheat a bit here, and install the seals on the VVT from the rear end of the cam, carefully seat it into the lower cam cover half after getting it square. I dress the lower half of the seal area with Permatex aviation gasket sealer to firm it up. I’ve done this on three VVT heads without leaks. That saves the locking of the cams and having to crack that nasty tight torx screw on the cam which is tough off car
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
abscate wrote: 30 Aug 2023, 04:09
I may try this today. Can I use any basic permatex from the auto part store?
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
wizechatmgr wrote: 29 Aug 2023, 23:32 Replaced the rear shock mounts on the '98 V70 today... Was doing the california lowrider/hydraulics thing when you stepped on the brakes. This would be why...
OMG mine were just as bad. I had to use a grinder to cut out the frozen nut on left side though. Off topic though: What dog do you have? Whenever I buy a new car, I strip all seats and covers out (excluding trim) to clean all that up. Occasionally (like once every 6-8mo) I do it again to keep the interior air clean.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Grunhilde was a kennel for a very large Shesdy German Shephard up in Vermont for a few years
ZionXIX wrote: 30 Aug 2023, 06:55
This is the stuff
https://www.amazon.com/gp/product/B000H ... =UTF8&th=1
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 30 Aug 2023, 10:51
This is the stuff
FTFY :wink:
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Finally replaced the coolant reservoir on my 99 s70.
Every now and then I would notice that my coolant level would dip. I'd add more. and it would vanish.
I suspected the cap, maybe something else, but then I shined a light into my reservoir and noticed all the crazing.
Maybe some of these cracks were letting pressurized vapor escape over time. Who knows.
I figured I'd replace the reservoir and cap to see if that made a difference. Super easy job once you figure out how to separate the coolant and power steering reservoirs . That was super frustrating until it because super easy. Just had to get a screw driver to release the top tongue of the power steering reservoir that locks it to the coolant reservoir.
we'll see if this solves my problem
