bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
ZionXIX wrote: 03 Sep 2023, 09:32
I actually had another question here. When you place the cams on the cylinder head, how do you know the proper orientation? Do you just eye ball the back side notches? I thought a cam locking tool was necessary when sett8ng time from scratch. Also do the cam shaft seat all the way down before tightening the cam cover bolts?
The cam locking tool makes this part easier, but it's not 100% necessary. The slots in the back of the cams align with the seam of the cam cover to the cylinder head. Exhaust slot is offset to the bottom side, intake if offset to the top side. Then bolt on the cam gears.
I like to use the cam lock to make it easier to preload the VVT. That can be a little tricky to do without turning the camshaft forward.
Has thanked: 1611 times
Been thanked: 4072 times
Rolled The Kat to JFK to pick up kid. She hums 27 mpg at 70 mph on the LIE
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
bmdubya1198 wrote: 03 Sep 2023, 13:43
Use the cam lock to save yourself the frustration. I used it after I bolted the cover down when I did my NA can swap. You want to make sure they are at least close to being in the proper orientation though, to avoid putting valves into pistons.
I suggest just investing (or borrowing) the tools to compress the cam cover for reinstalling all of the cover bolts.
People do it without the tool, but people also wind up asking how to repair stripped threads in the head after trying to install the cover without it. You're compressing valve springs and the threads in the AL head aren't always up to the task if you get aggressive on tightening.
bmdubya1198
Yup, get the cam tool set with those cam cover tools on eBay or Amazon. They're pretty cheap. Not the greatest quality, but they work if you don't do the job too frequently.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Will do. Thanks guys. I'm justva little nervous about my first head rebuild ever. But I have 2 wagons in need of head rebuilds waiting after this so the next one should go much quicker.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
My tiny contribution here :
DO NOT crank the little 7mm bolts of the cam holding tool down. I snapped one off inside the camshaft.
bmdubya1198
BlackBart wrote: 04 Sep 2023, 08:50 My tiny contribution here :
Yes, be VERY careful with those. Snug em down, no more than that.
bmdubya1198 wrote: 04 Sep 2023, 14:06
Finger tight, no tools
It’s the lugs that hold the cams, not the m6 screws
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1077 times
Post by volvolugnut »
I'm curious. Where do the M6 screws attach to the engine?
BlackBart
Post by BlackBart »
The threaded ends of the camshafts.
