1999 S70 GLT. I have a weird issue with the passenger side headlight. This one has me scratching my head. The left light has a focal point, the right one does not. No matter how i move or adjust the aiming nothing changes. I can put my hand on the lens the you see the light dull somewhat. there is no dimming of light on the left or right so I know it is not aimed way off. its like somehow what would normally be a beam directed forward is being diffused. Also i popped the clip holding the internal bracket in place and was able to pivot the inside bracket with the light on..made no noticeable difference..
I have a spare set of a donor car (not sure of year or model, but i place to check it out and see if i can figure out what is going on
I am including some pictures.
any ideas??
headlight conundrum 99 S70
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
I will add that the two lights look exactly the same looking into the assembly from the back.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Most likely the reflective coating gave up. Swap it out would be my suggestion.Grantkat wrote: 07 Sep 2023, 19:39 I will add that the two lights look exactly the same looking into the assembly from the back.
Several thousand keystrokes on here about our lights. Carefully curated used units or TYC seem to be the only reasonable fixes.
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
100% burned reflectors. Swap the one headlight for a good one and you’ll be back to normal. Mine did that too, same side (though I took the expensive route and went Jewels with projectors for far superior light output)
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Has thanked: 1613 times
- Been thanked: 4077 times
Reflectors are dulled but if you look closely you will find left amd right Volvo glass have different lenses , too
- Grantkat
thanks everyone...will do!
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
How to refurbish if the spares don't work out. Middle of the page.
viewtopic.php?t=100706&hilit=Project+2000&start=20
- 1897 Views
Last post by mrbrian200
- 443 Views
Last post by RickHaleParker
- 368 Views
Last post by moorlander
- 427 Views
- 10 Replies
- 3357 Views
Last post by esl_97_850_T5
