vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
P80GLT wrote: 14 Sep 2023, 15:05 30 minutes to get the alternator almost out, only to find out I needed to remove the top radiator hose.
Remove OTE pipe, throttle pipe, fan shroud, protect radiator with cardboard, slide alternator to the driver's side and take it out. Sounds like a lot of work, but it is quicker and less messy than draining the radiator.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
@ val: really wasn't a problem draining the coolant and I had tried sliding over but not enough clearance. Fan was out, dipstick tube loosened, charge pipes out but still not enough space...
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
P80GLT
Post by P80GLT »
I checked the coolant level this morning and it had indeed dropped down a little.
I managed to get all of the remaining coolant I removed yesterday back into the system.
I then decided to fit the microphone for the Bluemusic adapter
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Installed a shift handle, leather E-brake handle and two good boots that I had sourced from the junkyard several months ago. Also put in a different radio (my volume knob didn't work and the radio head would change input sources and frequencies on its own occasionally. Its a slightly different colour but it doesn't look too bad and works better than the one that came out.
The E-brake handle is leather, unlike my original plastic one. I'm not sure if they offered a leather handle in other years or if I got it off an S-60 maybe.......it sure is a nice improvement. Both my shifter boot and E-brake boot were in awful condition, the faux leather was peeling and cracking off.
shifter and boot.jpg (85.94 KiB) Viewed 667 times
2003 XC 70 (sold)
Has thanked: 2207 times
Been thanked: 1852 times
I take it you managed to get that door aligned like you hoped?
Blacklab467
Kinda Sorta, It closes nice and fits in the opening with uniform gaps but the bottom sticks out a little too much for my liking. Maybe if you're around next week we could get together if you're any good with aligning these?
2003 XC 70 (sold)
P80GLT
Post by P80GLT »
After fitting the new alternator I decided to check the battery side of things and whoever fitted the new Halford battery last year must have been on a budget and fitted a tiny 027. As I often travel up to the highlands in the snow I decided not to chance it and fitted an 096 Bosch battery today which is the size the 2.5T would have left the factory with. I know the battery tray will accommodate an 019 but as I don't have a diesel engine I felt that would be overkill for my car.
Halfords 027 (H5) Battery
Bosch 096 (H6) battery
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Post by vtl »
I had a biggest AGM battery that was able to fit in there. It lasted 10 years and then silently went south and killed my hand-rebuilt alternator. I saw the signs of bad battery, but was slacking for a year or so. This summer had to replace both alternator and the battery.
P80GLT
Post by P80GLT »
@ vtl I sold my 13 year old XC90 in April, it was still on its factory supplied battery. Wife's non Volvo car is 15 and still on factory battery. I do wonder if factory batteries are higher spec than we can buy.
2010 XC90 SE...SOLD
2005 V70 2.5T SE
vtl
Post by vtl »
P80GLT wrote: 19 Sep 2023, 10:11 @ vtl I sold my 13 year old XC90 in April, it was still on its factory supplied battery. Wife's non Volvo car is 15 and still on factory battery. I do wonder if factory batteries are higher spec than we can buy.
Depends on use case. I was traveling off the paved roads quite a bit, vibration and bumps is bad for batteries. In last 3 years the car was mostly sitting still, waiting for the engine and transmission rebuild. I "forgot" to put the battery on tethering charger, so it almost died. Then the car became a motorized grocery cart with short trips, which batteries hate.
