2008 C30 Fuse panel replacement
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 59 times
- Been thanked: 9 times
Looking to replace my fuse panel under passenger side dash. There was quit a bit of corrosion in it and my power drivers seat is not working. My scanner showing me that there is an issue in the CEM and I believe the unit needs to be replaced. My question is if I find a used unit with the same part number can I simply swap with mine or is there additional programming needed? 31254903 is the part number on mine and I am looking at one from an s40 that had the same box. Will it work?
- 1211 Views
Last post by volvolugnut
- 1384 Views
Last post by SuperHerman
- 11 Replies
- 3483 Views
Last post by cn90
- 1865 Views
Last post by erikv11
- 1182 Views
Last post by lummert
